UberNewbie can't set his clock...
Results 1 to 20 of 20
    sinoteq's Avatar
    sinoteq Guest
    Default Ds1302
    If you look at the datasheet for the DS you will se that you have to do some formating of the DS result before you can display it. The DS does not store each SEC MIN HOUR and so on as a byte, it is stored in a mixed byte (I bet Melanie knows the correct word for it)
    Example:
    The register for seconds is 8 bits wide but is split into a 10 SEC part and a SEC part. So you have to look at the DS data as (n*10SEC)+SEC.
    You have to move this into a byte before you can display it. I have never used DS1302 but I have used the DS1307 and the idea is similar.
    Please look at http://pdfserv.maxim-ic.com/en/ds/DS1302.pdf Table 3 page 9
    Melanie has all kinds of words for all kinds of situations... but in this instance I'll chose to use BCD (Binary Coded Decimal)...
  1. Interruptus Frustratus
    Last Post: - 17th April 2009, 21:36
  2. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
  5. How to set external clock source in PBP
    By TurboLS in forum mel PIC BASIC Pro
    Last Post: - 19th February 2005, 16:56
