interactive menu with hyperterminal
Results 1 to 13 of 13
    Still no problems Jamie.
    I get the same screen, and when pressing C it redraws the screen.
    Doesn't matter how many times or how fast I press C, it always comes up correct. I can press C fast enough that it misses some of them, but that's to be expected with SERIN2.
    Do you have any other ANSI sequences in your program?
    Dec 2008
    Default Thanks Darrel
    No, thats the whole routine. I'm going to reinstall hyper terminal. This glitch never made any sense to me. Thank you for all your help!!!!
    I know its not the code now. I'll update when I get it squared away.. has to me my pc.
    Jamie
    Jumping in late here with a quick thought....
    Are you by any chance using a USB<->RS232 dongle? I've never had a problem with those myself but I've read about some weird behaviour. I know you said that the transfer was rock solid "otherwise" which may point away from said dongle - but then it would point away from the PC and terminal softwaret too.
    Anyway, just a thought.
  1. load .hex file in PIC with hyperterminal
    By irenuska23 in forum General
    Last Post: - 1st September 2009, 10:52
  2. Hyperterminal problem
    By DR.Larq in forum Serial
    Last Post: - 9th May 2008, 19:40
  3. Replies: 1
    Last Post: - 30th March 2008, 16:53
  4. Sending menu to PC from PIC16F876A
    By joseph Degorio in forum Serial
    Last Post: - 12th November 2007, 08:03
  5. Interrupt Menu System Example and Help Needed
    Last Post: - 1st April 2005, 18:05
