interactive menu with hyperterminal
Results 1 to 13 of 13
    Dec 2008
    Default Thanks for the replies
    I tried character pacing and it had no effect on the way the menu displays. just mad it slower. I also tried making a new hyperterminal window also with no change. the menu displays the same on realterm and teraterm so the 1 line scrolling in hyperterminal was also not the problem.
    Thank you for trying
    jamie
    I've run the routine you supplied, well ... had to add some stuff cause it was just a snippet, and my crystal was different.
    It ended up looking like this ...
    DEFINE OSC 10
    SO  VAR PORTC.6
    SI  VAR PORTC.7
    Bank0A     CON 0 ; No idea
    RTCHr      VAR BYTE : RTCHr     = $17
    RTCMin     VAR BYTE : RTCMin    = $44
    RTCSec     VAR BYTE : RTCSec    = $28
    RTCMonth   VAR BYTE : RTCMonth  = 1
    RTCDate    VAR BYTE : RTCDate   = 3
    RTCYear    VAR BYTE : RTCYear   = 9
    SamTime    VAR BYTE : SamTime   = 12
    SYSVolts   VAR BYTE : SYSVolts  = 5
    DirtyMem   VAR BIT  : DirtyMem  = 1
    TurStatus  VAR BIT  : TurStatus = 1
    LogData    VAR BIT  : LogData   = 1
    PCCommand VAR BYTE  : PCCommand = 0
    ADDR      VAR BYTE  : ADDR      = 0
    Cont      VAR BYTE  : Cont      = 0
    Serout2 SO,32,[" ITCV2.0 Turbine Controller (SW - V1.0) System Voltage is ",Dec SYSVolts," Volts", 10,13]
    Serout2 SO,32,[" < ",HEX2 RTCHr,":",HEX2 RTCMin,":",HEX2 RTCSec," ",HEX2 RTCMonth,"/",HEX2 RTCDate,"/",HEX2 RTCYear," Sample time = ",Dec SamTime," Sec >",10,10,13]
    If DirtyMem <> 255 Then
    Serout2 SO,32,[27,91,53,109," MEMORY Contains DATA!",27,91,48,109,10,10,13] ' flash the text
    EndIf
    If TurStatus <> 255 Then
    Serout2 SO,32,[27,91,53,102," TURBINE IS DE-ACTIVATED!",27,91,48,109,10,10,13] ' flash the text
    EndIf
    Serout2 SO,32,[ " (1) Turbine Setup Menu (2) Download Memory Banks",13,10]
    Serout2 SO,32,[ " (3) Erase Memory Banks (4) Set the sample time",13,10]
    Serout2 SO,32,[ " (5) Set the Clock (6) Log Data ("]
    If LogData = 1 Then
    Serout2 SO,32,[ "ON)",13,10]
    Else
    Serout2 SO,32,[ "OFF)",13,10,13,10]
    EndIf
    Serout2 SO,32,[ " (C) CLEAR THE SCREEN",10,13]
    Serout2 SO,32,[ "HOLD (A) while LOGGING returns to this menu",13,10]
    SerIn2 SI,32,[PCCommand]
    If PCCommand = 49 Then TurbineSetup
    If PCCommand = 51 Then ClrMem
    If PCCommand = 53 Then SetClock
    If PCCommand = 52 Then SampleTime
    If PCCommand = 67 Or PCCommand = 99 Then Menu
    If PCCommand = 54 Then
    If LogData = 0 Then LogData = 1:GoTo Menu
    If LogData = 1 Then LogData = 0:GoTo Menu
    EndIf
    If PCCommand = 50 Then
    Serout2 SO,32,[ 13,10]
    ADDR = 0
    Cont = Bank0A
    GoTo DumpMem
    EndIf
    TurbineSetup:
    ClrMem:
    SetClock:
    SampleTime:
    Menu:
    DumpMem:
    And here is what it displayed ...
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=3092" /><!-- Name:  Menu.gif
Size:  15.8 KB -->
    The problem doesn't seem to be in that routine.
    Maybe somewhere else in the code?
    Need more Input.
    Dec 2008
    Default Thanks Darrel
    Darrel, Thats exactly as it's supposed to look. Thank you for verifying the code. I wonder if you hit 'C' and clear the screen a bunch of times does it screw up the display for you?
    I will keep searching. That routine is was screws up on my end. if I try adding menu items (7) and (8) ect it really messes up.
    I will look at it much closer
    Thanks for taking the time Darrel
    Jamie
    Quote Originally Posted by jamied View Post
    The location MENU: (result of "C" PCCommand = 67) wasn't included in the snippet.
    Can I assume it's the routine shown?
    Happy to test any portions provided.
    Dec 2008
    Default Sorry about that
    I just realized the menu: lablel was missing from the top of the text
    That whole routine is called menu so when you hit 'C' it just repaints it while clearing the screen
    I added the routine Clearscreen: a few weeks ago to try and solve my problem but it never helped.
    here it is
    DEFINE OSC 10
    SO VAR PORTC.6
    SI VAR PORTC.7
    Menu:
    Serout2 SO,32,[27,91,48,109]
    GoSub ClearScreen:Serout2 SO,32,[27,91,48,109]
    EndIf
    EndIf
    If LogData = 1 Then
    Else
    EndIf
    EndIf
    ADDR = 0
    Cont = Bank0A
    GoTo DumpMem
    EndIf
    ClearScreen:
    serout2 SO,32,[27,91,50,74]
    TurbineSetup:
    ClrMem:
    SetClock:
    SampleTime:
    Menu:
    DumpMem:
    Still no problems Jamie.
    I get the same screen, and when pressing C it redraws the screen.
    Doesn't matter how many times or how fast I press C, it always comes up correct. I can press C fast enough that it misses some of them, but that's to be expected with SERIN2.
    Do you have any other ANSI sequences in your program?
    Dec 2008
    No, thats the whole routine. I'm going to reinstall hyper terminal. This glitch never made any sense to me. Thank you for all your help!!!!
    I know its not the code now. I'll update when I get it squared away.. has to me my pc.
    Jamie
  1. load .hex file in PIC with hyperterminal
    By irenuska23 in forum General
    Last Post: - 1st September 2009, 10:52
  2. Hyperterminal problem
    By DR.Larq in forum Serial
    Last Post: - 9th May 2008, 19:40
  3. Replies: 1
    Last Post: - 30th March 2008, 16:53
  4. Sending menu to PC from PIC16F876A
    By joseph Degorio in forum Serial
    Last Post: - 12th November 2007, 08:03
  5. Interrupt Menu System Example and Help Needed
    Last Post: - 1st April 2005, 18:05
