Quote Originally Posted by aratti View Post
Led var portX.x
A0 var Byte
Loop:
For A0 = 1 to 10
Toggle Led
Pause 50000
next A0
'comment the 3 lines hereunder for only ten flashes (leave the END)
Low Led
Pause 5000
goto Loop
This Example will flash led ten times. Led will turn off for 5 secs and flashing will repeat.
Hope it is what you need.
Happy new year
Al.
when I write
If button1 = 0 then test
test:
for a0 = 1 to 10
toggle led
pauseus 50000
next a0
low led
pauseus 50000
What happens is the led only flashes 4 times. I am using a 12F683 @ 8mhz OSC
