Count Bits, Choose High or Low?
Results 1 to 4 of 4
    Jan 2006
    Istanbul
    IF DT's routine is too complicated for you, which usually is for me, then take a look at this one.
    This should be faster then yours I guess.
    <font color="#000000">ErrorCheck:
        HighCount = <font color="#FF0000">0
        </font>LowCount  = <font color="#FF0000">8
        </font>i         = <font color="#FF0000">0
        </font><font color="#000080"><b>WHILE </b></font>i &lt; <font color="#FF0000">8
              </font>n = testByte.<font color="#FF0000">0</font>[i]          <font color="#000080"><i>'Read bit.
              </i></font>LowCount  = LowCount - n   <font color="#000080"><i>'sub. bits.
              </i></font>HighCount = HighCount + n  <font color="#000080"><i>'add bits.
              </i></font>i = i + <font color="#FF0000">1                  </font><font color="#000080"><i>'incr. bit.
        </i><b>WEND
        </b></font>testByte = <font color="#FF0000">$00                    </font><font color="#000080"><i>'Assign value.
        </i><b>IF </b></font>HighCount &gt;= LowCount <font color="#000080"><b>THEN </b></font>testByte = <font color="#FF0000">$FF  </font><font color="#000080"><i>'change value if true.
    </i><b>RETURN
    </b></font>
    Edit: I did not understand the logic behind this statement:
    "This will eliminate any bit errors as long as it's not more than 3 bit errors per byte."
    You may cut the loop off if this is true and reduce the time into half of what it takes.
    Aug 2007
    Very much appreciated guys. That worked perfectly.
    Darrel's code wins though. Indeed, about 16uS. Sayzer's loop took about 112uS. An improvement but still not quite fast enough.
    If there was ever any question about the efficiency of assembly or the lack of efficiency of PBP, I guess we see it right here. lol.
    Anyway, that totally solves my problem - thank you both very much!
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 20:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  3. Microcontroller with 2 way paging application problem
  4. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 02:37
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 14:31
