This should take about 13us at 16Mhz.
When it's finished the number of 1's in the byte will be in BitCount.Code:BitCount VAR BYTE BANK0 testByte VAR BYTE BANK0 LoopCount VAR BYTE BANK0 testByte = %00100100 ASM MOVE?CB 8, _LoopCount ;2 loop through 8-bits MOVE?CB 0, _BitCount ;2 clear the Bit Count TestLoop ifdef BSR ; for 18F's rrcf _testByte, F ;1 rotate LSB into carry else ; for 16F's rrf _testByte, F ;1 rotate LSB into carry endif btfsc STATUS, C ;1 if a 1 rotated into carry incf _BitCount, F ;1 increment the Bit Count decfsz _LoopCount, F ;1 skip if rotated all bits goto TestLoop ;2 do the rest of the bits ENDASM
The number of 0's, would be 8-BitCount.
And the testByte variable will have been destroyed.
hth,
