Q: using MCLR for Input on 12F683
Page 1 of 2 12 LastLast
Results 1 to 40 of 47
    Default Q: using MCLR for Input on 12F683
    When configuring MCLR'/VPP as GP3 for input on the 12F683, do you program it afterwards via the same protocol - i.e.- does the programming function of the MCLR'/VPP pin change, or will I still be able to program via ICSP as normal?
    Nov 2007
    West Covina, CA
    Default From the start
    You can set it up for an input from the beginning of the program then still use it later for programming. Just make sure your circuit will still allow the Vpp signal to control it during programming otherwise it will boop at you and report an error.
    Louie
    And make sure you circuit will handle the programming voltage.
    I like to use some method of isolation when programming. The simplest is a two pin header with a jumper clip.
    Default 2-pin header
    Makes sense, thanks guys - I had planned on input circuit isolation at the pin, but wasn't sure if there was some other issue that I'd run into during subsequent programming...
    Thanks again, and happy new year all!
    Default Help - 12F683 and servo control in Picbasic
    Hi, new to this forum and to PIC's in general. I fly RC and have used a 12F683 to act as failsafe system for 3 servos.
    I've tried the pulsout command but the output just goes HI?? (I have scope to check).
    Here is the code:
    pos var byte ' Define our storage location for the servo position information.
    servo var byte ' Define our storage location for the servo number to move.
    cont var byte ' Define a variable to hold the count.
    ' 4 mhz clock internal
    ' 500 = 1 ms
    ' 1000 = 2 ms
    ' 1250 = 2.5 ms
    pos = 1250
    start:
    for cont = 0 to 50
    pulsout portb.4,pos ' Send servo# ? to position ?.
    pause 20 ' Wait 20 ms.
    next cont ' Next pulse.
    goto start ' Return to get more serial input.
    Can anyone help??
    Try changing pos to a WORD size var and see if that helps
    Question
    Thanks! it worked on the 16F84A chip.
    I'm still having difficulty with the 12F683 though. The pulsout doesn't seem to work. I wonder if the chip supports that command?
    I've also tried running the servo by setting the pin high and low timing the high between 1 to 2 ms and the low to 20ms. It works, but it won't accept a decimal number.
    at 4 mHz, I need to pause for between .5ms and 2.5ms but it only accepts 1 and 2 !!!
    suggestions??
    John.
    p.s., here's the code:
    posit var word
    cont var word
    cont2 var word
    Q var word
    let posit = 3/2
    Let Q = 25
    start:
    for cont = 1 to 50
    high 0
    pause posit
    low 0
    pause 20
    next cont
    goto start
    Nov 2007
    West Covina, CA
    It doesn't show in your code so I will assume that the device has not been configured to what you want to do with it since it has other features.
    Start by setting the oscillator then the ports with the TRISIO command, found on page 35 of the data sheet, shut OFF the comparators and the A/D feature:
    OSCCON = %01100000  ' Ocs set to 4 MHz
    TRISIO = %00000000  ' Set all ports to outputs, in this example
    CMCON0 = 7                ' Analog comparators off
    ANSEL  = 0                ' Analog select set to digital, pg 69 data
    ADCON0 = 0                ' A/D turned OFF, pg 68 of data
    Then use the PAUSES command instead of PAUSE for a better resolution of the timming you need:
    PAUSE 1 gives you 1ms where PAUSES 1000 will do the same but now you can get your 1.5ms with PAUSES 1500.
    Last edited by LinkMTech; - 3rd January 2009 at 04:49. Reason: Then use GPIO.# not PORT.#
    Louie
    Nov 2007
    West Covina, CA
    Red face One more thing
    Didn't know how to edit last post so:
    Use GPIO.# instead of PORTB.# per pg. 35 of data sheet.
    Louie
    Oct 2007
    The Netherlands
    That should be PAUSEUS not PAUSES.
    PAUSEUS will pause microseconds, not milliseconds.
    If you let PBP devide 3 by 2 then you will always get 1 as an answer.
    So if you want to pause 1.5 milliseconds use PAUSEUS 1500 instead.
    happy new year
    Thanks LinkMtech and eggman (sounds like a TV show in the making!). I'll try your comments today.
    Happy new year to both of you.
    John.
    Thanks gents, both option worked like a charm.
    Cheers!
    OK, anthor problem...
    I'm trying to run an RC servo from a PIC12F683. I'm using pin 0 as output and pin 1 as input (from receiver)
    As long as there is a signal from pin 1, the PULSOUT will output the PULSIN value. When no signal is present (PULSIN=0) then PULSOUT should go to a failsafe value.
    Situation: When the signal is present, the PULSOUT sends the PULSIN value, but when PULSIN = 0, the PULSOUT does send the proper value, but in 1/2 second intervals (it pulses the value about every 0.5 sec). I can't figure out why!!!
    here's the code:
    oSCCON = %01100000 ' Ocs set to 4 MHz
    cont var word
    failsafe var word
    posoutput var word
    posinput var word
    usefailsafe var byte
    pausetime var word
    low gpio.0
    low gpio.1
    low gpio.2
    low gpio.3
    failsafe=80
    pausetime=10
    START:
    ;pulsout portb.4, failsafe
    ;pause 50
    ;goto start
    GETSIGNAL:
    pulsin gpio.1,1,posoutput
    if posoutput=0 then goto runfailsafe
    goto runnormal
    runfailsafe:
    pulsout gpio.0, failsafe
    pause pausetime
    goto getsignal
    runnormal:
    pulsout gpio.0, posoutput
    pause pausetime
    goto getsignal
    I have one more...
    I want to write the PULSIN value to the memory on the 12F683 (and have it stored even when the power is off) and recall it in the event there is no PULSIN signal.
    What are the proper commands to do this?
    (I assume write and read)
    I.e.
    WRITE 5, failsafe
    READ 5, failsafe
    ...but first I have to get the servo thing working!!
    This may help with your data storage.
    The below code is for a counter, sort of like an odometer. It saves the value to EEPROM at each hit of a switch. When the device is turned on the EEPROM is read and the values placed back into a variable for continued use. Also has the ability to reset the stored values back to zero at start up.
    Pick through it and see if it helps.
    '*  Notes   :16F877A
    '*   SAVE TO EEPROM
     '_config _HS_OSC & _WDT_ON & _LVP_OFF & _CP_OFF &_BODEN_OFF
    DEFINE OSC 20
    DEFINE LCD_DREG     PORTB
    define LCD_DBIT     4
    DEFINE LCD_RSREG    PORTB
    DEFINE LCD_RSBIT    1
    DEFINE LCD_EREG     PORTB
    DEFINE LCD_EBIT     0
    DEFINE LCD_BITS     4
    DEFINE LCD_LINES    2
    DEFINE LCD_COMMANDUS    2000
    DEFINE LCD_DATAUS   50
    TRISA = %00000000
    ADCON1=14
    Asm
        ERRORLEVEL -306
    Endasm
    include "modedefs.bas"
    'TOTAL VARS
    O	VAR	BYTE	'ONES
    T	VAR	BYTE	'TENS
    H	VAR	BYTE	'HUNDREDS
    TH	VAR	BYTE	'THOUSANDS
    TTH	VAR	BYTE	'TEN THOUSANDS
    HTH	VAR	BYTE	'HUNDRED THOUSANDS
    M	VAR	BYTE	'MILLIONS
    OD	VAR	BYTE	'ONES
    TD	VAR	BYTE	'TENS
    HD	VAR	BYTE	'HUNDREDS
    THD	VAR	BYTE	'THOUSANDS
    TTHD	VAR	BYTE	'TEN THOUSANDS
    HTHD	VAR	BYTE	'HUNDRED THOUSANDS
    MD	VAR	BYTE	'MILLIONS
    'TOTAL LOGS
    O_LOG	VAR	BYTE	'ONES
    T_LOG	VAR	BYTE	'TENS
    H_LOG	VAR	BYTE	'HUNDREDS
    TH_LOG	VAR	BYTE	'THOUSANDS
    TTH_LOG	VAR	BYTE	'TEN THOUSANDS
    HTH_LOG	VAR	BYTE	'HUNDRED THOUSANDS
    M_LOG	VAR	BYTE	'MILLIONS
    'READ LOGS
    READ O_LOG, OD
    READ T_LOG, TD
    READ H_LOG, HD
    READ TH_LOG, THD
    READ TTH_LOG, TTHD
    READ HTH_LOG, HTHD
    READ M_LOG, MD
    NUM	VAR	BYTE
    NUM = 0
    CHECK:
    IF PORTE.2 = 1 THEN GOSUB CL_LOG 'FOR RESET AT START UP
    IF PORTE.2 = 0 THEN START
    GOTO CHECK
    START:
    HIGH PORTD.2      'LED
    PAUSE 5
    IF PORTD.3 = 1 THEN GOSUB C_P_T  'SWITCH FOR PARTS
    LOW PORTD.2
    PAUSE 5
    GOTO START
    C_P_T:
    LCDOUT $FE,1,"C TEST"
    LCDOUT $FE,$C0,DEC MD,DEC HTHD,DEC TTHD,DEC THD,DEC HD,DEC TD,DEC OD
    O = O + 1
    IF O = 10 THEN
    O = 1
    T = T + 1
    	IF T = 10 THEN
    	T = 0
    	H = H + 1
    		IF H = 10 THEN
    		H = 0
    		TH = TH + 1
    			IF TH = 10 THEN
    			TH = 0
    			TTH = TTH + 1
    				IF TTH = 10 THEN
    				TTH = 0
    				HTH = HTH +1
    					IF HTH = 10 THEN
    					HTH = 0
    					M = M +1
    WRITE O_LOG, O
    WRITE T_LOG, T
    WRITE H_LOG, H
    WRITE TH_LOG, TH
    WRITE TTH_LOG, TTH
    WRITE HTH_LOG, HTH
    WRITE M_LOG, M
    READ O_LOG, OD
    READ T_LOG, TD
    READ H_LOG, HD
    READ TH_LOG, THD
    READ TTH_LOG, TTHD
    READ HTH_LOG, HTHD
    READ M_LOG, MD
    CL_LOG:
    HIGH PORTD.2
    PAUSE 100
    LOW PORTD.2
    PAUSE 100
    O = $0
    T = $0
    H = $0
    TH = $0
    TTH = $0
    HTH = $0
    M = $0
    WRITE O_LOG, O
    READ O_LOG, OD
    WRITE T_LOG, T
    READ T_LOG, TD
    WRITE H_LOG, H
    READ H_LOG, HD
    WRITE TH_LOG, TH
    READ TH_LOG, THD
    WRITE TTH_LOG, TTH
    READ TTH_LOG, TTHD
    WRITE HTH_LOG, HTH
    READ HTH_LOG, HTHD
    WRITE M_LOG, M
    READ M_LOG, MD
    Nov 2007
    West Covina, CA
    Default Timing out
    I found that PULSIN will time out while you're waiting for something to happen then was clued in on WHILE:WEND.
    So try this command set with something like:
    WHILE GPIO.1 = 0    ' Repeat this loop while there is no signal
    pause pausetime
    WEND
    It comes in handy for something like this.
    Louie
    Thanks LinkMTech and Mackrackit:
    Both worked. FYI, I fly RC planes and have recently gained interest in the PIC stuff, mostly with the 12F683 due to its size. I'm learning this stuff...slowly (but wow, has it got potential!).
    I have a couple more questions hopefully you can help me with.
    1. having some issues simply running LED's on ports other than gpio.0 and 1. I'm not sure if I need to assign them, change them??? When trying, I see they have a faint glow???
    2. When using GPIO.4 and an input to store a pulsin value, the program works, but if I use GPIO.3 it doesn't. I can't figure that one out.
    Thanks again gents.
    John.
    Default Beware PULSOUT as a failsafe
    I crashed my RC aircraft using the PULSOUT command.
    PULSOUT is a 'toggle'. Whatever state the pin was in, it will flip for the duration specified in the PULSOUT command. That is bad news if your servo pin gets clobbered and you were expecting it to be low when you called the PULSOUT routine.
    To be safe, you MUST predefine the pin state before calling PULSOUT.
    e.g.
    LOW ServoPin
    PULSOUT ServoPin, 500
    will work every time.
    HTH
    Brian
    Quote Originally Posted by johnnylynx View Post
    Thanks again gents.
    John.
    Can you post your code?
    Whoops, sorry about that!
    here's the code:
    input gpio.4
    inpulse VAR Word
    memory var word
    low gpio.4
    low gpio.3
    start:
    SEROUT 0, 2, [12]
    start2:
    PULSIN 1, 1, inpulse
    if inpulse<50 then
    read 5, memory
    serout 0,2,[12,17, "Activating",13,"Failsafe :", #memory*10]
    goto start2
    if gpio.4=1 then
    write 5, inpulse
    serout 0,2,[12,17,"Failsafe",13,"Stored :", #inpulse*10]
    high gpio.3
    low gpio.4
    low gpio.3
    SEROUT 0, 2, [17,22,#inpulse*10]
    PAUSE 20
    GOTO start
    Quote Originally Posted by BrianT View Post
    e.g.
    LOW ServoPin
    HTH
    Brian
    Thanks Brian, I've got the pulsout working...actual pretty good now. Just some issues with getting gpio.2 and gpio.3 to simply operate LED's!
    My code is posted above.
    Cheers,
    John.
    input gpio.4 '<font color=red> make input</font color>
    inpulse VAR Word
    memory var word
    low gpio.4 <font color = red> ' Now you make it an output</font color>
    low gpio.3
    start:
    SEROUT 0, 2, [12]
    start2:
    if inpulse<50 then
    read 5, memory
    goto start2
    if gpio.4=1 then '<font color=red> still an output, are you wanting an input?</font color>
    write 5, inpulse
    high gpio.3
    low gpio.4 '<font color=red> is and should be an output</font color>
    low gpio.3
    PAUSE 20
    GOTO start
    Thanks Joe,
    I didn't catch that, I'll make changes and see if that fixes the input problem.
    I still have the output issue though with GPIO.3, it doesn't want to run the LED.
    Any thoughts?
    John.
    Not sure but I think that pin is input only.
    I dunno John, I never use the High / Low convention, preferring to specify TRISIO AND GPIO instead because as I understand it , High/Low reads modify's and writes the whole port ( all the I/Os ) when you do.
    Thanks guys,
    I think I've got it working OK now...but by copy of the picbasic compiler (with microcode studio) only limits me to 31 code lines
    As much as I like Microcode Studio...is there something out there a guy can use that is much cheaper than picbasic pro AND is downloadable from the NET?
    John.
    May 2007
    http://www.oshonsoft.com/pic.html
    About US$70, Unlimited demo, FREE for 30 days.
    http://www.mikroe.com/en/compilers/mikrobasic/pic/
    US$149, FREE demo limit 2K code (with the PIC12F683, you fill the entire program memory with the demo).
    Thanks, how do these compilers compare to picbasic pro?
    John.
    May 2007
    John.
    I suggest that you download the demos (and relevant user manuals) and judge for yourself. I think you will be pleasantly surprised.
    May 2007
    Oops, left out my favorite (only for PIC18's though) - US$149, Demo limited to 256 bytes of RAM, no restrictions on code size:
    http://www.sfcompiler.co.uk/swordfish/
    I tried mikrostudio...I like the picbasic code better (maybe because I'm learning on that platform). I also have MPLAB that came with my pickit2...but it works on asm. I appears if I get the picbasic compiler that I could program in MPLAB using picbasic???
    Is that right?
    JOhn.
    MPLAB and PBP work very well together. I normally use MPLAB over MCS.
    http://www.melabs.com/support/mplab.htm
    Sep 2007
    USA, CA
    I was looking in to C compilers last year, and got some great feedback from a guy whose job requires him to be familiar with just about every pic compiler. (His feedback was offline, because he could not post his opinions public for the same reason he knows about all of the compilers. I am going to respect his anonymity.) Anyway, his advice regarding Mikroe and their compilers was to avoid them, for a variety of reasons. (Which mostly boiled down to "you get what you pay for.")
    I own PBP, and find it a great compiler for people wanting to step up from Stamps. I mostly use Proton Basic (PDS), however, because it compiles much more compactly (about 20%) and runs faster. It's only $165, and even comes with a simulator that allows you to step through your code and debug much faster. The sim is limited to a couple chips and a couple development board models, but that allows you to test routines without messing with hardware. (I purchased the full sim so I can create just about any circuit I can think of--but that is not cheap.)
    For the most part, you get what you pay for in compilers. Comparing PBP to PDS, they are very similar (they both used BS2 as a base), but PDS is more powerful. The same guy mentioned above said PDS "is as close to coding in asm as it gets for any pic compiler." The biggest difference is that PBP is a little more oriented (better oriented?) towards beginners because it has fewer features to trip you up. PDS has a larger command set, and built in interrupt context saving. The parser is better with PBP, so you can string together many math equations on one line with lots of parentheses to make it readable...but if you separate them out and use PDS, your code will be a LOT smaller.
    May 2007
    Would you care to share the reasons why your guy said to avoid mikroE?
    Sep 2007
    USA, CA
    This is what he said that I can share: "mikroC has a good support of internal libraries but the binary code is not that optimized". Like I said, the rest boiled down to "you get what you pay for." If you want cheap, you get cheap... either minimal features, buggy or bloated code. Nobody makes a compiler that is bug-free, optimized, and feature-full.
    And, more importantly for me, I use the Proteus PIC/Spice simulator for debugging my code, and the Mikro compilers put out a proprietary format (not a standardized format), so it is only useful for use with their own debugger.
    You can always use PicBasic (instead of PicBasic Pro), which is a lot cheaper, and almost certainly bug-free... but it has minimal features and no optimization. There's also the free Pascal-like compiler, JAL: http://www.voti.nl/jal/
    while cheaper is not always better, even if you pay a single full license for Hi-Tech C (more than 2K) but cover ALL PIC familly (from 10F to Dspic, PIC32), you won't have the peace of mind. Most of those I know of, have now moved on Microchip ones. OK they're still expensive, but they seems to be better with years than Hi-Tech (That's what i've heard and experimented myself awhile back).
    However, the only single language that cover EVERY PIC familly and which is free is ASM. That's great, but a real pain to program in, and it's syntax change from a familly to another, more noticeable on DsPIC/PIC32. Good news is, the only person you will be abe to blame when a bug will appear one day or another is you.
    Depending where you are located in the product food-chain, ASM is great or bad.
    For every compiler on the market, we heard good and bad comments... same things goes for all device programmers, IDE, etc etc etc. What I hate is to learn 3,4,5,6,7...10 different compiler to do a single job.
    Knowing your compiler is great, knowing your own limit is great, ASM cover everything, but you must know and admit your personal limit/time.
    It's a full piece of crap to say that ASM is faster... it's really up to the pepper back of the keyboard.... hence why performance of each and eavery compiler differ for the same single task.
    Time wasting... is this a real waste, or knowledge improvement... who knows? On the other side, who care of a developer knowledge if another do it WAY faster... once it's burned in a black pinned box, and do the job as per the customer requirement, no one will care of the tool you used.
    Same bull**** happen with PC... C is better than Basic... euh NO SIR your $%!$%^#@ wrong C#... Delphi... Python....Java is better... crap crap crap... unfortunately, actual market is... faster is better... crap crap crap...
    Default Compilers
    Wow, seems I opened up a can of worms there
    I was looking over ASM earlier (from a beginners perspective) and learned how to convert binary to hex (amazingly simple...after a 3-finger scotch!)
    Still, ASM, as you all have essentially indicated, is ... a pain.
    I'm checking out PDS...and don't see if it supports pickit2 and a programmer (anyone know?).
    I think i'll end up purchasing either PDS or PBP...both look great!
    Thanks for all you're input!
    John.
    The PICKIT2 will load the generated hex, does not matter who or what created it.
    Can of worms?
    What did you expect, I like Fords, are they better
    May 2007
    I agree with with Dave, that is why I suggested that you try them out and judge for yourself rather than relying on the opinion of third parties. I did indicate my favorite though - just like Dave did.
    I was going to try PDS...but the trial version doesn't support the 12F683. I will have to pick up some 12F675's or the 16F628A to try PDS out.
    John.
  1. How to MCLR by code for 16F877
    By fbestepe in forum mel PIC BASIC Pro
    Last Post: - 26th November 2014, 01:51
  2. 12F683 - Pin1 not working
    Last Post: - 8th February 2014, 18:38
  3. 16f677a to 12f683
    Last Post: - 25th July 2007, 07:16
  4. What does this MCLR instruction mean?
    By bartman in forum General
    Last Post: - 30th November 2004, 01:32
  5. I/O pin and MCLR
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 15th July 2004, 11:52
