Hold the phone folks; I think I may have a hardware issue. I almost hope so, anyway. heh.
BBIAF...
SmugWimp
BBIAF...
SmugWimp
No Such Luck. What I thought was a miswiring turned out to be correct. But I did remove some (as of yet) unneeded wires for the buttons, until I get the rest of this moving along. It doesnt work any better, but it is easier to see.
Here is the latest rendition of code:
Interestingly enough, One of the reasons I thought it was a hardware failure, was I could remove one, or both of the I2C lines and still not get an error (evidenced by the optional jump label on the first I2CWRITE command, to reset the NS73M). However, if I "swapped" the lines, then I DID get a "No ACK" error. Weird. I still dont understand that. But it is wired correctly.Code:REM LCD PIN Assignments above... NS_DA VAR PORTB.1 NS_CK VAR PORTB.2 MYCON VAR BYTE 'REM Control Value for NS73M START: 'REM The Theory is that we setup all parameters, then turn it on. MYCON = $CC 'REM Setup Control Address for NS73M PAUSE 100 'REM Breathe a moment; let the chip get settled... REM I2CWRITE DATAPIN,CLOCKPIN,CONTROLADDRESS,PORTADDRESS,[DATAINBRACKETS]{, OPTIONALJUMPTOLABEL} I2CWRITE NS_DA,NS_CK,MYCON,$0E,[$05], BOOHA 'REM SOFTWARE RESET NS73M Chip PAUSE 10 I2CWRITE NS_DA,NS_CK,MYCON,$00,[$A0] 'REM Set it up, dont turn it on yet... PAUSE 10 I2CWRITE NS_DA,NS_CK,MYCON,$01,[$B4] 'REM Pilot On, Subcarrier On PAUSE 10 I2CWRITE NS_DA,NS_CK,MYCON,$02,[$07] 'REM 2mw Power, Unlock Detect ON PAUSE 10 I2CWRITE NS_DA,NS_CK,MYCON,$03,[$58] 'REM Frequency; Lower Byte PAUSE 10 I2CWRITE NS_DA,NS_CK,MYCON,$04,[$2A] 'REM Frequency; Upper Byte PAUSE 10 I2CWRITE NS_DA,NS_CK,MYCON,$08,[$1A] 'REM CEX Band 2 PAUSE 10 I2CWRITE NS_DA,NS_CK,MYCON,$00,[$A1] 'REM Ok, Turn it on... PAUSE 10 I2CWRITE NS_DA,NS_CK,MYCON,$0E,[$05] 'REM SOFTWARE RESET NS73M Chip PAUSE 100 I2CWRITE NS_DA,NS_CK,MYCON,$06,[$1E] 'REM Charge Pump PAUSE 10 LCDOUT $FE, 1 LCDOUT $FE, 2 PAUSE 500 LCDOUT $FE, $80 LCDOUT "Transmitting?" LCDOUT $FE, $C0 LCDOUT " supposedly..." PAUSE 1000 GOTO THEEND BOOHA: LCDOUT $FE, 1 LCDOUT $FE, 2 PAUSE 500 LCDOUT $FE, $80 LCDOUT "No ACK" LCDOUT $FE, $C0 LCDOUT ":(" PAUSE 1000 GOTO THEEND THEEND: END
I moved back to a 16F84A because it wasnt the problem and I have a bunch that I want to use.
On the 16F84A, Pins A0-4 are used for data and RS for the LCD. Pin B0 is the E pin for the LCD, B1 is the I2C Data line, and B2 is the I2C Clock.
On the SparkFun board, Line In is attached to my Ipod, IIC is attached to +3.3v, LA is attached to Ground, Data to B1, Clock to B2, TEB not connected, VCC to +3.3v and Ground to Ground.
Again, It seems like it "should" work, but alas it does not. Any ideas would be greatly appreciated!
Cheers!
SmugWimp
Just a guess here but the NS73M is not 5V tolerant. The pins connected to the PIC should be level compensated to match the logic levels required for the NS73M or a 3V PIC should be used.
I use the NS73M quite reliably but not in I2C mode and my routines are written in Swordfish so I can't really comment on your code. Sorry I can't help more.....
Tom
Tom
Tom, Thanks!
Yeah, I have the NS73M on the end of a 3.3v regulator, and all but the LCD is on 3.3v.
If I cant get I2C working, I guess I will go with the 3 wire... but was hoping not to have to use that extra pin...
So goes life...
Cheers!
SmugWimp
Hello SmugWimp,
16F877a has a bunch of analog stuff, some of it on portC, including C.1 and you must disable to send I²C as that data is digital. How about posting the whole code including the config statements. I would read sec. 4.3 of the data sheet, it explains about using portC in I²C communications and which pins to use. I do not know how much it affects the operation, but portC has Schmitt trigger input buffers. It may be because of that, it will only work on the pins Microchip has designated as I²C , it is certainly worth the effort to check. BTW, I do not see the jump label or a subroutine to be jumped to, must be in the unposted code . . . Have you attempted to try this on PortB ? No S. T. on the inputs there. here is a link of someone who got I²C to work : http://www.picbasic.co.uk/forum/showthread.php?t=5632 Looks like I2CWRITE is not a stand alone statement, looks like it requires all the registers to be set as the datasheet specifys . . . The manual gives the impression this is a bit banged solution, sort of looks like it is not.
Look at this thread it discusses using I²C w 3.3v . . . http://www.picbasic.co.uk/forum/show...9879#post69879 I noticed a comment re: not using schmitt trigger inputs . . .
Joe,
I appreciate all the help and suggestions.
Here is my code, a schematic, and a photo of my setup.
I have tried all kinds of things, and my underlying suspicion isnt that I am doing something wrong. I am just not finished with what is right.
I have rewritten my code more similar to Boris' snippets, and his seems to work, heh. But mine still does not. Yet.
My Configs are set as follows:
__config _HS_OSC & _WDT_ON & _LVP_OFF & _CP_OFF & _WRT_OFF & _CPD_OFF & _BODEN_ON & _PWRTE_ON
Code:''''''''''''''''''''''''''''''''''''''' ''''''''''''''''''''''''''''''''''''''' '' NS73M Control Test Environment '' ''''''''''''''''''''''''''''''''''''''' ''''''''''''''''''''''''''''''''''''''' ' We are using a PIC 16F877A ' ADCON1=%00000111 Include "ModeDefs.Bas" DEFINE OSC 4 TRISB=0 DEFINE LCD_DREG PORTA 'Define PIC port used for LCD Data lines DEFINE LCD_DBIT 0 'Define first pin of portb connected to LCD DB4 DEFINE LCD_RSREG PORTA 'Define PIC port used for RS line of LCD DEFINE LCD_RSBIT 4 'Define Porta pin used for RS connection DEFINE LCD_EREG PORTB 'Define PIC prot used for E line of LCD DEFINE LCD_EBIT 0 'Define PortB pin used for E connection DEFINE LCD_BITS 4 'Define the 4 bit communication mode to LCD DEFINE LCD_LINES 2 'Define using a 2 line LCD NS_CK VAR PORTB.1 ' I2C Clock Pin NS_DA VAR PORTB.2 ' I2C Data Pin NS_CON VAR BYTE ' I2C Device (the NS73M) Control Address/ReadWrite Value NS_REG VAR BYTE ' NS73M Register Address NS_VAL VAR BYTE ' NS73M Register Value NS_CON = %11001100 ' Value of NS73M Address, with "Write" Bit NS_REG=$0E:NS_VAL=$05:GOSUB WRITEDAMMIT ' Reset the chip right off... They said to. NS_REG=$01:NS_VAL=$B4:GOSUB WRITEDAMMIT ' Pilot On, Forced Subcarrier On NS_REG=$02:NS_VAL=$07:GOSUB WRITEDAMMIT ' Full (2mw) Power, Unlock Detect On, NS_REG=$03:NS_VAL=$58:GOSUB WRITEDAMMIT ' Lower Byte of Freq Address in Hex NS_REG=$04:NS_VAL=$2A:GOSUB WRITEDAMMIT ' Upper Byte of Freq Address in Hex NS_REG=$08:NS_VAL=$18:GOSUB WRITEDAMMIT ' CEX Band = 3 (For Now. Different Bands for Different Freq's) NS_REG=$00:NS_VAL=$A1:GOSUB WRITEDAMMIT ' Xmtr RF On, 200mv input level for 100% Modulation NS_REG=$0E:NS_VAL=$05:GOSUB WRITEDAMMIT ' Another Reset NS_REG=$06:NS_VAL=$1E:GOSUB WRITEDAMMIT ' Set the Charge Pumps, whatever Charge Pumps are... GOTO LCDSTUFF WRITEDAMMIT: I2CWRITE NS_DA,NS_CK,NS_CON,NS_REG,[NS_VAL] ' I2CWRITE Command. Supposed to work. PAUSE 10 ' Don't know if this is necessary, but everyone writing to EEProms use it, I figured it couldn't hurt. RETURN LCDSTUFF: LCDOUT $FE, 1 LCDOUT $FE, 2 PAUSE 500 LCDOUT $FE, $80 LCDOUT " Are We" LCDOUT $FE, $C0 LCDOUT "Transmitting ??" PAUSE 1000 THEEND: END
I know the chip in the schematic says "16F84AP". disregard that. In reality, it is a 16F877A; the pin connections are the same still.
Any ideas would be a godsend. Thanks!
Cheers!
SmugWimp
