Hi Boris!
Got my chips in today from Sparkfun, and started reading the datasheet on the NS73M a bit more.
It seems that although the NS73M can read and write, the only thing I can see is that it is 'writing' is an ACK for any commands sent, but that seems to be about the only information that I can find in the datasheet.
If you were (like me) planning to read the NS73M to see what parameters it is currently set at then we may end up going another method.
I suspect I will end up using a "set" of defaults, and then use the PIC to read/modify/write those settings in the EEPROM as needed.
Let me know if you see something different!
Cheers!
Alex
