NS73M fm radio trasmitter
Results 1 to 22 of 22
    Boris, Any luck on this? I will be moving into an NS73M from a BH1417.
    Jun 2006
    The NS73M works without problem, but I could not read the registers. I can write them, so I can set the frequency and all parameter, but no read...
    Not trying to cheat, but if you would not mind sending me a couple of lines of your sample code so I will have something to work with starting out I would appreciate it.
    Reading the registers of the NS73M? I guess my first question is why? I am not sure what the advantage or use would be.
    Cheers!
    SmugWimp
    Jun 2006
    This is my code:
    EEPROM 0,[3,232,0,0]    'FREQ.BYTE1 FREQ.BYTE0 PW SENS
    READ 0,FREQ.BYTE1
    READ 1,FREQ.BYTE0
    READ 2,PW
    READ 3,SENS
    SETUP:
       REG=$0E:VAL=$05:GOSUB SCRIVI         ' Software reset
       REG=$01:VAL=$B4:GOSUB SCRIVI     ' Pilot on, forced subcarrier
       REG=$02:VAL=$07:GOSUB SCRIVI  ' 2 mW power, Unlock detect on  REG=$08:VAL=$1A:GOSUB SCRIVI     ' CEX = Band 2
       REG=$00:VAL=$A1:GOSUB SCRIVI     ' Pwr on, 200 mV audio for 100% modulation
       REG=$06:VAL=$1E:GOSUB SCRIVI' Set internal charge pumps
    SCRIVI:
    I2CWRITE DA,CK,%11001100,REG,[VAL]
    Boris,
    Much Appreciated! Not sure if I can do anything about reading registers, I am just beginning. But I can get anything to work, I will post it here.
    Cheers!
    SmugWimp
    Hi Boris!
    Got my chips in today from Sparkfun, and started reading the datasheet on the NS73M a bit more.
    It seems that although the NS73M can read and write, the only thing I can see is that it is 'writing' is an ACK for any commands sent, but that seems to be about the only information that I can find in the datasheet.
    If you were (like me) planning to read the NS73M to see what parameters it is currently set at then we may end up going another method.
    I suspect I will end up using a "set" of defaults, and then use the PIC to read/modify/write those settings in the EEPROM as needed.
    Let me know if you see something different!
    Cheers!
    Alex
    I guess I am missing some elementary issues, but I cannot seem to figure out why I cannot get this to work.
    Here is a sample of my code:
    REM Above this is just LCD and button setups...
    NS_CK VAR PORTC.1
    NS_DA VAR PORTC.2
    FREQ VAR WORD 'REM Consisting of FREQ.1 and FREQ.2 (Hi/Lo Byte)
    MYREG VAR BYTE 'REM Register of NS73M
    MYVAL VAR BYTE 'REM Value for register in NS73M
    MYCON VAR BYTE 'REM Control Value for NS73M
    START:
    'REM The Theory is that we setup all parameters, then turn it on.
    MYCON = %11001100 'REM Setup Control Address for NS73M
    PAUSE 100 'REM Breathe a moment; let the chip get settled...
    I2CWRITE NS_DA,NS_CK,MYCON,$0E,[$05] 'REM SOFTWARE RESET NS73M Chip
    PAUSE 100
    I2CWRITE NS_DA,NS_CK,MYCON,$01,[$B4] 'REM Pilot On, Subcarrier On
    PAUSE 10
    I2CWRITE NS_DA,NS_CK,MYCON,$02,[$07] 'REM 2mw Power, Unlock Detect ON
    PAUSE 10
    I2CWRITE NS_DA,NS_CK,MYCON,$08,[$1A] 'REM CEX Band 2
    PAUSE 10
    'REM Again, theory is that I am transmitting on 88.5MHz, as per datasheet...
    I2CWRITE NS_DA,NS_CK,MYCON,$03,[$58] 'REM Frequency; Lower Byte
    PAUSE 10
    I2CWRITE NS_DA,NS_CK,MYCON,$04,[$2A] 'REM Frequency; Upper Byte
    PAUSE 10
    I2CWRITE NS_DA,NS_CK,MYCON,$00,[$A3] 'REM Power, 200mv Audio, 75us PE
    PAUSE 10
    PAUSE 10
    I2CWRITE NS_DA,NS_CK,MYCON,$06,[$1E] 'REM Charge Pumps
    PAUSE 10
    PAUSE 10
    REM Just a note to let me know it got through the code unscathed...
    	LCDOUT $FE, 1
    	LCDOUT $FE, 2
    	PAUSE 500
    	LCDOUT $FE, $80
    	LCDOUT "Transmitting?"
    	LCDOUT $FE, $C0
    	LCDOUT "  supposedly..."
    	PAUSE 1000
    At first I was trying this with a 16F84A, and moved to a 16F877A just to make sure there was nothing wrong with my chips. I get the same results; nothing.
    This is my first attempt at I2C communications, so I am not certain what, if any, feedback I can expect. My current feedback is nothing works, lol!
    Any pointers on where my code is lacking, or erroneous, would be greatly appreciated!
    Cheers!
    SmugWimp
  1. Car radio (Car radio and electronics support forum)
    By freewillover in forum Forum Requests
    Last Post: - 1st July 2009, 20:41
  2. FM Radio transmitter PIC Interface.
    By koossa in forum Off Topic
    Last Post: - 30th November 2008, 10:05
  3. Replies: 5
    Last Post: - 6th September 2007, 05:59
  4. Newbie radio link issue
    By George in forum mel PIC BASIC Pro
    Last Post: - 28th February 2007, 05:28
  5. LPRS/miniature radio modules
    By fowardbias in forum Off Topic
    Last Post: - 20th September 2005, 02:03
