NS73M fm radio trasmitter
Results 1 to 22 of 22
    Jun 2006
    Default NS73M fm radio trasmitter
    Have somebody used this chip (from sparkfun.com)?
    I'm trying to read the registers, but my firmware don't works.
    Boris, Any luck on this? I will be moving into an NS73M from a BH1417.
    Jun 2006
    The NS73M works without problem, but I could not read the registers. I can write them, so I can set the frequency and all parameter, but no read...
    Not trying to cheat, but if you would not mind sending me a couple of lines of your sample code so I will have something to work with starting out I would appreciate it.
    Reading the registers of the NS73M? I guess my first question is why? I am not sure what the advantage or use would be.
    Cheers!
    SmugWimp
    Jun 2006
    This is my code:
    EEPROM 0,[3,232,0,0]    'FREQ.BYTE1 FREQ.BYTE0 PW SENS
    READ 0,FREQ.BYTE1
    READ 1,FREQ.BYTE0
    READ 2,PW
    READ 3,SENS
    SETUP:
       REG=$0E:VAL=$05:GOSUB SCRIVI         ' Software reset
       REG=$01:VAL=$B4:GOSUB SCRIVI     ' Pilot on, forced subcarrier
       REG=$02:VAL=$07:GOSUB SCRIVI  ' 2 mW power, Unlock detect on  REG=$08:VAL=$1A:GOSUB SCRIVI     ' CEX = Band 2
       REG=$00:VAL=$A1:GOSUB SCRIVI     ' Pwr on, 200 mV audio for 100% modulation
       REG=$06:VAL=$1E:GOSUB SCRIVI' Set internal charge pumps
    SCRIVI:
    I2CWRITE DA,CK,%11001100,REG,[VAL]
    Boris,
    Much Appreciated! Not sure if I can do anything about reading registers, I am just beginning. But I can get anything to work, I will post it here.
    Cheers!
    SmugWimp
  1. Car radio (Car radio and electronics support forum)
    By freewillover in forum Forum Requests
    Last Post: - 1st July 2009, 20:41
  2. FM Radio transmitter PIC Interface.
    By koossa in forum Off Topic
    Last Post: - 30th November 2008, 10:05
  3. Replies: 5
    Last Post: - 6th September 2007, 05:59
  4. Newbie radio link issue
    By George in forum mel PIC BASIC Pro
    Last Post: - 28th February 2007, 05:28
  5. LPRS/miniature radio modules
    By fowardbias in forum Off Topic
    Last Post: - 20th September 2005, 02:03
