LCD menu
Results 1 to 5 of 5
Thread: LCD menu
    Jan 2008
    Default LCD menu
    I have 3 buttons and a 2x16 LCD and want to have an LCD menu and navigate with the 3 buttons.
    I want to use 2 of the buttons for UPP/DOWN in the menu and the last one for Enter.
    How do I do that in a smart way.
    I could use a lot of IF THEN ELSE with some GOTOīs but i donīt feel that its the right way to do it.
    So help me, how should I build the code.
    Cool
    Quote Originally Posted by Fredrick View Post
    You could use Select case, you might even get 7 or 8 states out of those 3 switches.
    Whatever you do If-Then will be there....
    I don't like it either but don't see doing it other way.
    P.S. I do it once with only 2 buttons as i lack the 3rd one. Very awkard...
    Yes, there is always another way...
    One of my products (on an 18F2420) has a 5 level Menu structure, that is 170 items deep! With 3 Button Control and an LCD. It is on a product which sells 1000/month and which competitors can't figure how it's done! So I won't give you the code, because it'll hand them the secret (and I know they read this forum)... but I will generalise...
    The Menu consists of a 8 Byte Table per line... the Table is held in program codespace (see elsewhere on this forum how to do that).
    Byte 1 tell the Menu Subroutine what kind of Data Element we are dealing with... ie, Numeric, Numeric with Fixed Decimals, Alphanumeric, Date, Time etc.
    Byte 2 is the Data Element Byte Length.
    Byte 3 is the Minimum permitted value for any Numeric entry.
    Byte 4 is the Maximum permitted value for any Numeric entry.
    Byte 5 are Flags... these are Bits that Control frills, eg Cursor ON/OFF, Visible or Invisible Entry (like that required for Passwords) , whether Data-Entry is permitted or not, etc etc
    Byte 6 points to the location in EEPROM where the first Byte of Data is to be found.
    Byte 7 points to the Message in Program Codespace which will appear on your LCD prompting your Data-Entry (eg "Enter Time Delay").
    Byte 8 points to a secondarry Message in Program Codespace for additional information (eg "Minutes").
    The Menu Subroutine, sequentially reads the eight control bytes and acts on it accordingly. Once you have built your subroutine, it's a simple matter of adding just eight bytes (plus prompting messages) per Menu item. It's small, it's compact, and everything you need to learn how to do it is on this forum somewhere (though not in a ready cut & paste form). Clue: It does rely very heavilly on reading large Tables of Data from Program Codespace and manipulating Alphanumeric STRINGS (for all the LCD Messages) with PBP. Sort out how to do that first, and the rest is simple!
    Nice one Mel. I suppose that this part is one ofthe memory hungry ones.
  1. 16f688 LCD what have I done wrong
  2. Play with LCD on PICDEM
  3. Sending menu to PC from PIC16F876A
    By joseph Degorio in forum Serial
    Last Post: - 12th November 2007, 07:03
  5. LCD will not start
