Please help with code for DS18B20
Results 1 to 40 of 110
    When I tried for that and with one sensor, it shows -0.06 Celsius. and the sensor would not respond for variation
    Some ( wrong ! ) values have a typical meaning :
    0.06 as a "measure " shows a connecting ( or sensor ) problem ... Check your DQ line ...
    85 shows conversion not completed ...
    Mar 2006
    Hyderabad (India)
    Fratello's code has definite mistakes, and need attention. With the mistakes How it was working for him is a wonder.The suspected line numbers, i shall be indicating for consideration / possible correction.
    I suspect that the code posted by him at #35 is not what he might be using.
    Sarma
    Default ???
    Hi, Sarma
    What are you talking about ???
    Fratello's code can of course bear some little improvements but WORKS FINE !!!
    ( I just translated it to a 16F877A aboard an Easy Pic 5 ... and it's nice.)
    PS: do not tell me you are waiting for custom code or you do not have something personnal working since the 8th of April ... please ...
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
