Please help with code for DS18B20
Results 1 to 40 of 110
    Dec 2008
    Ploiesti, ROMANIA
    I found this on forum :
    "OSCCON = %01100000 'Internal clock set to 4-MHz (MUST DO THIS!!!)"
    I added in my code, but PBP say "Error : Undefined Symbol 'OSCCON'.
    Maybe this is the error that shows different temperatures ?
    Have you checked your PICs DATASHEET to see if it has an OSCCON register?
    Dec 2008
    Ploiesti, ROMANIA
    My mistake...mea culpa...
    Dec 2008
    Ploiesti, ROMANIA
    Based on the book mentioned at post #21, I re-write the code for this project. I implement a new procedure for initializing the sensors. The results are verry good. Want somebody to improve this ? I wish You all the best !
    Thanks again for Your support !
    Mar 2006
    Hyderabad (India)
    Quote Originally Posted by fratello View Post
    @Fratello,
    is your latest software working in the range 0 to 100 deg Celsius at least?
    When I tried for that and with one sensor, it shows -0.06 Celsius. and the sensor would not respond for variation
    We have presently temperatures around 33.5 Celsius, as we entered summer season in India.
    Sarma
    Dec 2008
    Ploiesti, ROMANIA
    The code is ok ! Check the DS18B20 serials numbers ! I don't know if the thermostat work with just one sensor ! Good luck !
    Mar 2006
    Hyderabad (India)
    as long as a working project of elektor is modded by adding another sensor, it should work for a single sensor also. I have just disabled all lines pertaining to sensor2.
    I am asking for practical test result, not the program being OK as per our assumption, please. whether you are able to read temperature like normal room and and a piece of ice ? with one of the sensors, with other sensor reading just room temp?
    Sarma
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
