Please help with code for DS18B20
Results 1 to 40 of 110
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply !
    Sorry, but my LCD is 2 x 16 ; at first line I display "In" and at second "Out" values of temperatures. Otherwise, nice code are You writing .
    Dec 2008
    Ploiesti, ROMANIA
    New problem :
    -the thermometer PIC 12F675 + DS18B20 + Nokia LCD = 24.5 'C
    -the thermometer LM 35DZ + Fluke 830DM = 24.5 'C
    -the thermometer PIC 16F628A + DS18B20 = 25.5 ' C !!!!!!!!!!!
    I try to write in PIC the same code of themperature conversion like Mr.Novakovic Ivica.
    Check for similarity !!!! Why this diference ? I thing I go crazy, soon ....
    Wink
    count_remain, count_per_c
    DO NOT use that with DS 18B20 ....
    That's a first step.
    Dec 2008
    Ploiesti, ROMANIA
    Anything code I write in thermo that I made, the temperatures are NOT similar with those measured with other devices (mentioned). I try to change the sensor (I use three !) but nothing change. I don't know what to believe : which of temperature is - more- accurate ?
    Dec 2008
    Ploiesti, ROMANIA
    I found this on forum :
    "OSCCON = %01100000 'Internal clock set to 4-MHz (MUST DO THIS!!!)"
    I added in my code, but PBP say "Error : Undefined Symbol 'OSCCON'.
    Maybe this is the error that shows different temperatures ?
    Have you checked your PICs DATASHEET to see if it has an OSCCON register?
    Dec 2008
    Ploiesti, ROMANIA
    My mistake...mea culpa...
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
