Please help with code for DS18B20
Results 1 to 40 of 110
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for support !!!!
    First code (post #18) return this result : 28 CA C6 48 1 0 0 A7
    Second code (post # 22) return : CA C6 48 01 00 00
    In the code that I write now I use something like this :
    "Init1
    OWOut DQ, 1, [$55, $28, $FE, $DA, $3E, $0, $0, $C1, $4E, $FF, $FF, $7F]
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $48]
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $B8]
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $BE]
    Pause 1000
    OWOut DQ, 0, [Temperature.Byte0, Temperature.Byte1, 0, 0, DS18B20_12bit]
    Init2
    OWOut DQ, 1, [$55, $28, $FE, $DA, $3E, $0, $0, $C1, $4E, $FF, $FF, $7F] 'SENSOR 2 !!!!!!!!! not reading yet !!!!
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $48] 'SENSOR 2 !!!!!!!!! not reading yet !!!!
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $B8] 'SENSOR 2 !!!!!!!!!
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $BE] 'SENSOR 2 !!!!!!!!!
    Pause 1000
    Main
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $44] ' Start temperature conversion Sensor 1
    WaitLoop:
    While not DQ
    Wend
    OWIn DQ, 0, [Temperature.Byte0, Temperature.Byte1]
    GoSub Convert_Temp
    GoSub DisplayTemp
    Part2
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $44] ' Start temperature conversion Sensor 2
    WaitLoop2:
    While not DQ
    Wend"
    I hope it's good...will see !
    Dec 2008
    Ploiesti, ROMANIA
    Hello !
    Me again ......I write the code attached, but the temperature on display don't modify (IN = 91.25 'C ; OUT = 25.18 'C)... Know somebody where is the mistake ? Thanks in advance...
    Dec 2008
    Ploiesti, ROMANIA
    I found the mistakes ! I re-re-re...-write te code. Now works fine !
    I did it !! I am verry happy ! I take a little pause -just a few hours- and I will try to adapt this code to the old code of thermostat, for having both function : dual termometre and thermostat. I will keep you informed ! All the best !
    I know the accuracy is +/- 0.5 'C , but it is normal this ? One sensor show 25.21 'C and the other 26.18 'C... I put the sensors together, and I fix them with one earring, this is the temperatures after 15 min... Maybe i's something wrong in my code ?!
    Dec 2008
    Ploiesti, ROMANIA
    Hope I am not boring with this subject !
    1. I replace one sensor and now both temperatures are similar.
    2.I write the code for dual thermometer and thermostat ; works verry good !
    If somebody have idea to improve this code, please post here !
    I wish you all the best !
    Hi, Fratello
    What about a nice Bargraph to show what's going on ... ???
    like this one :
    '                              AFFICHAGE
    'Motifs CGRAM
          LCDOUT  $FE,$40,$00,$00,$00,$00,$00,$04,$04,$04  ' Cust Char $0 'Small bar
          LCDOUT  $FE,$48,$00,$00,$00,$04,$04,$04,$04,$04  ' Cust Char $1 'Mid bar
          LCDOUT  $FE,$50,$04,$04,$04,$04,$04,$04,$04,$04  ' Cust Char $2 'Big bar
          LCDOUT  $FE,$58,$04,$04,$0E,$0E,$0E,$1F,$1B,$11  ' Cust Char $3 'Arrow
          LCDOUT  $FE,$60,$11,$1B,$1F,$0E,$0E,$0E,$04,$04  ' Cust Char $4 'Inv Arrow
          LCDOUT  $FE,$68,$04,$04,$0E,$1F,$1F,$0E,$04,$04  ' Cust Char $5 'Diamond
    Aff:'Affichage temp
    'préparation chiffre : sign = 1 = valeur négative
    Decal	= ( TempC // 5 ) << 1
    IF NOT sign THEN
    	Loscale = ( TempC /5 ) * 5
    	Hiscale = (( TempC /5 ) + 1) * 5
    	IF Float > 25 AND Float <= 75 then Decal = Decal + 1
    	IF Float > 75 Then Decal = Decal + 2
    	Loscale = (( TempC /5 + 1 ) * 5) * -1
    	Hiscale = ((TempC /5) * 5 )* -1
    	Decal = 10 - Decal
    	IF Float > 25 AND Float <= 75 then Decal = Decal - 1
    	IF Float > 75 Then Decal = Decal - 2
    		TempC = TempC * -1
    'Impression valeurs 1ère ligne
    IF Sign THEN
      LCDOUT	$FE, $80 ,SDEC2 Loscale,178,Unit," "
      IF TempC = 0 THEN LCDOUT "-"
      LCDOUT SDEC TempC,".",dec2 Float
      IF ABS TempC < 10 then LCDOUT " "
      LCDOUT $FE,$80 + 11,SDEC2 Hiscale,178,Unit
      LCDOUT	$FE, $81 ,SDEC2 Loscale,178,Unit," ",SDEC TempC,".",dec2 Float
      IF TempC < 10 then LCDOUT " "
      LCDOUT $FE,$80 + 12,SDEC2 Hiscale,178,Unit
    'Impression échelle 2ème ligne
     LCDOUT	$FE,$C0,$01,$00,$02,$00,$01,$00,$01,$00,$01,$00,$01,$00,$02,$00,$01,$00
    'Impression index
     IF Tempeff < ( Setpoint - 5 ) THEN
    	LCDOUT	$FE, $C2 + Decal,$03				'Index Chauffage
     	IF Tempeff > ( Setpoint + 5 ) THEN
    		LCDOUT	$FE, $C2 + Decal,$04				' Index Refroidissement
    		LCDOUT	$FE, $C2 + Decal,$05				' Index Zone neutre
    Better shown on attachment
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply !
    Sorry, but my LCD is 2 x 16 ; at first line I display "In" and at second "Out" values of temperatures. Otherwise, nice code are You writing .
    Dec 2008
    Ploiesti, ROMANIA
    New problem :
    -the thermometer PIC 12F675 + DS18B20 + Nokia LCD = 24.5 'C
    -the thermometer LM 35DZ + Fluke 830DM = 24.5 'C
    -the thermometer PIC 16F628A + DS18B20 = 25.5 ' C !!!!!!!!!!!
    I try to write in PIC the same code of themperature conversion like Mr.Novakovic Ivica.
    Check for similarity !!!! Why this diference ? I thing I go crazy, soon ....
    Apr 2011
    Default Re: Please help with code for DS18B20
    Quote Originally Posted by fratello View Post
    "Init1
    Pause 1000
    Init2
    Pause 1000
    Main
    WaitLoop:
    While not DQ
    Wend
    GoSub Convert_Temp
    GoSub DisplayTemp
    Part2
    WaitLoop2:
    While not DQ
    Wend"
    I try to read serial number in my DS18B20:
    first sensor 28D698D7400F8
    second sensor 28FED6D64002B
    third sensor 2880DC3C2009E
    but how I put it in the code with $ ?
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
