Please help with code for DS18B20
Results 1 to 40 of 110
    Dec 2008
    Ploiesti, ROMANIA
    Thank you all for reply !
    In this book : "PIC Microcontrollers: Know It All" from Lucio Di Jasio, Tim Wilmshurst, Dogan Ibrahim, John Morton, Martin Bates, Jack Smith, D.W. Smith, and Chuck Hellebuyck - witch is my inspiration , I read this :
    "Dallas Semiconductor’s 1-wire specifications define device serial numbers as 8 bytes (64 bits) long.The family code for 18B20 digital thermometer chips is $28. The CRC (cyclic redundancy code) is an error-checking feature, so that, should we desire, we may verify that the 56 bits of the family code and serial number have been correctly received and were not corrupted. We’ll not further consider how CRCs are calculated, as it’s a topic well beyond the level of this introductory book.
    When we run the program, we see the following output:
    28 4C D4 3E 0 0 0 D6
    The digits 4C D4 3E 0 0 0 D6 are, of course, dependent upon the particular DS18B20 chip.
    I plugged in a second DS18B20 chip and found its serial number:
    28 FE DA 3E 0 0 0 C1
    In the output, $28 is the family number and $D6 (or $C1 in the second example) is the CRC. The center six bytes represent the serial number of the chip. But, here’s a difference between the result and the serial number specification isn’t there? The definition has the CRC sent first and the family code sent last. Yet, Program 22.1 displays the family code first, and the CRC last.The explanation is that 1-wire devices store the least significant byte at the lower address and
    the most significant byte at the higher address. Bytes are transmitted and received from lowest address to highest address. Hence, the net effect is the send/receive byte order is reversed from the data sheet description. This is more confusing to describe than to use; when we wish to address a particular device, we just repeat the byte order we read with Program 22.1"
    So, I think it is enough for me these results.
    Next step is : Reading multiple sensors on the same bus.
    ... Wish me luck !
    I will keep you informed and - hope- I will receive yours advices again.
    All the best !
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
