Please help with code for DS18B20
Results 1 to 40 of 110
    Wink
    Ok, Mel
    You're talking resolution while I'm talking accuracy ...
    DS already give .0625°C resolution ... but that do not mean anything because you only know you are inside the +/- 0.5 °C error gap.
    LM 335 have your ADC resolution ... but always an "out of the box" +/- 0.5 °C precision
    That is why I say ( and repeat ... ) you can't get a better reading WITHOUT a calibration ... or comparison with a known reference.
    Even the MS5534 ( 16 bits! ) which comes with its calibration coeffs ... is given for a GUARANTEED +/- .8°C accuracy ...
    For NTC's the problem is the +/- 5 to 20% value tolerance ... that need an individual curve adjustment to each sensor ( only 1 point ... yes... but one point calibration ! )
    The only **predictable** High accuracy sensors are Platinium RTD's ... But , ... How much to pay for a class A probe ??? ...
    Temp and Thermal measurements are always funny ... and make you humble !!!
    Dec 2008
    Ploiesti, ROMANIA
    Thank you for replays !!!
    I wish to all a happy NEW YEAR 2009 !
    I think I go crazzy with this little thermostat probleme ; I write ( based on Yours great codes) four routines ; everyone display a different temperature. Which of them is -in yours opinion - the best ?
    1.OWOut DQ, 1, [$CC, $BE]
    OWIn DQ, 2, [Temperature.Lowbyte, Temperature.Highbyte]
    Convert_Temp:
    Dummy = 625 * Temperature
    TempC = DIV32 10
    TempC = (Temperature & $7FF) >> 4
    Float = ((Temperature.Lowbyte & $0F ) * 25 )>>2
    Temperature = TempC*100 + Float
    2.OWOut DQ, 1, [$CC, $BE]
    OWIn DQ, 2, [RAWTEMP.Lowbyte, RAWTEMP.Highbyte]
    Convert_Temp:
    dummy = RAWTEMP * 625
    TempC = DIV32 100
    Temperature = TempC
    3.OWOut DQ, 1, [$CC, $BE]
    Convert_Temp:
    4.OWOut DQ, 1, [$CC, $BE]
    OWIn DQ, 0, [Temperature.LowByte, Temperature.HighByte, Skip 4, Count_Remain, Count_Per_C]
    Convert_Temp :
    Temperature = (((Temperature >> 1) * 100) - 25) + (((Count_Per_C - Count_Remain) * 100) / Count_Per_C)
    if Temperature > 32767 then '32767 check if BIT12=1
    Temperature= ~Temperature
    temperature=temperature>>3 ; divide by 8
    Thanks in advance for your support ; I hope I don't became boring !!!!
    Wink
    Hi, Fratello
    Too wide a question ... It's on your own now.
    Here it's yours to take :
    1) your Datasheets, and do not mix different sensors ( ! ), see how values are coded for each.
    2) your PbP Manual, and look at how PbP can calculate and see where roundings can lead to ( small ...) outputted value differences.
    Dec 2008
    Ploiesti, ROMANIA
    I use the same sensor, the same circuit, just I re-write the code...the results are never the same...
    Gabestarting's Avatar
    Gabestarting Guest
    Unhappy
    I intend to start tomorrow with the same project, using the same sensor DS18S20. May i use it without changing the code?
    Gabestarting Guest
    Sorry, reading the text again i observed that i have the right sensor, i was lucky...So, the thermostat works fine, i am happy for the bas-file, however it is easier to understand than assembler. I made the circuit on a stripboard. Have a nice evening!
    Dec 2008
    Ploiesti, ROMANIA
    I want now to try to read the temperature with two sensors DS18B20 ; one for IN and other for OUT. It is possible ? How can I display both temperatures ?
    Help, please !
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
