Please help with code for DS18B20
Results 1 to 40 of 110
Threaded View
  1. #4
    Talking The Horrible truth ...
    Quote Originally Posted by fratello View Post
    B.t.w : what can I use instead of DS18B20 for more accurate measurement ?
    Hi, Fratello
    I had a look to all the sensors you can find on the market ...
    The best "out of the box" accuracy ( all including ) will be roughly +/- 0.5 °C ... don't be sad !!!
    going further needs multipoint CALIBRATION ... with some really expensive devices.
    Note linearity is "not so bad" in our measuring range ... so, with a two points calibration ( 0 and 100°C ) , you can reach +/- 0.1 °C without too much pain.
    And remember ... DS18x20 in continuous measurement mode like here, without being fixed on a heatsink, has a 1°C self heating value ... ( a look at the Datasheet will confirm !!! )
    Just have a look to the values displayed from the power up ...
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
