Please help with code for DS18B20
Results 1 to 40 of 110
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Please help with code for DS18B20
    My opinion : MUST connect the LED trough resistor (R=U/I ; where U=5V and I depend on LED colour) ...
    Oct 2010
    it is strange because most of the times PICs can directly drive loads until 100mA. The leds get something like 10mA or less. The thing is that it looks like some pulses coming up from the pin. Can i test the PIN without any load on it with an oscilloscope? IF i have pulses then can we identify what the problem should be?
    Quote Originally Posted by astanapane View Post
    it is strange because most of the times PICs can directly drive loads until 100mA. . . .
    Ok I took this comment out of context . . . 100 ma if all port pins have a load on them distributed across the entire port . . . 25ma max on a single output pin. . . unless I misread the data sheets.
    Oct 2010
    Fratello,
    i have changed your code a little bit, only a very simple thing in order to have two outputs.
    instead of this
    If V < TargetTemp - Hyst then ' Below Target temperature - Hysteresis
    PORTA.2=1 ' Activate Warm Output
    PORTA.3=0 ' Deactivate Cold Output
    EndIf
    If V > TargetTemp + Hyst then ' Above Target temperature + Hysteresis
    PORTA.2=0 ' Deactivate Warm output
    PORTA.3=1 ' Activate Cold Output
    EndIf
    i used this
    EndIf
    EndIf
    If V2 < TargetTemp - Hyst then ' Below Target temperature - Hysteresis
    EndIf
    If V2 > TargetTemp + Hyst then ' Above Target temperature + Hysteresis
    EndIf
    and now i have two outputs. Very simple change but useful.
    I used to manipulate the ports directly, but once I had a problem and suspicion have fallen on the technique among other things.
    So, I now only use HIGH and LOW commands even if these eat a little program memory just to be sure.
    If your code is small enough to fit in one page then you probably can use direct port control.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
