Please help with code for DS18B20
Results 1 to 40 of 110
    Oct 2010
    Default Re: Please help with code for DS18B20
    Hi Ioannis,
    Yes, i have added the lines Fratello told me in order to activate the outputs.
    It should not do this. The code has some kind of hysteresis which prevents the play at he output.
    What if you increase this hysteresis?
    Dec 2008
    Ploiesti, ROMANIA
    I made tens of this thermostat, for all my friends, relatives....without troubles. Maybe it's time to show us Your schematic !
    May we ALSO see your FULL code ???
    Oct 2010
    Yes sure, i will upload the code soon, and i will also make a small video if you want.
    On the output, i have done the following configurations.
    1) only an LED
    2) light the LED through resistor.
    3) light the LED through a transistor.
    In case number 1. the 3MM LED does not go ON but it flashes very low with some pulses, it is not noticeable. (the 5 mm goes on)
    In case number 2. the LED works just fine
    In case number 3. the LED works just fine
    My question is, if anyone understands why it does not light up straight from the PIC (pin) output with no transistor or resistor.
    thanks a lot and sorry for the trouble
    I can only assume an overload with some kind of interference with something else around...
    I would never load directly PIC output pins.
    Dec 2008
    Ploiesti, ROMANIA
    My opinion : MUST connect the LED trough resistor (R=U/I ; where U=5V and I depend on LED colour) ...
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
