Please help with code for DS18B20
Results 1 to 40 of 110
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Please help with code for DS18B20
    Yes, it's right what you say in post #71 !
    Put this in top of code :
    @ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON
    define osc 4
    REMOVE Xtal and caps (no need quartz precision) ; or keep it - but then replace "Intosc_osc_noclkout" with "XT_Osc".
    Now you MUST have something on display !
    Oct 2010
    i've tried it but nothing on the lcd again,
    i think it has to do with the osc commands and there is the problem.
    i put a 4mhz ceramic with two legs, i idid also tried the ceramic 4mhz with 3 legs. Nothing on the screen.
    i'm sad that cannot complete it.
    thanks a lot for your help! am i doing something wrong with the schematic? Do i need anything else?
    The code from the elektor works, but i dont have the ds1820. And it is on the screen xxx.xx
    But i dont understand why it does not work with your code.
    Aug 2010
    Maryland, USA
    First you need to prove the pic is running. There are no caps shown in above schematic at the xtal, do you have caps on it? Have you made a led blink? Did you try internal osc?
    From the quick skim I did on this thread, it seems I have read several posts claiming the code works. Time to look at your hardware.
    -Bert
    Oct 2010
    ok i will try later this afternoon to blink an led.
    Do i need capacitors for the ceramic 4 mhz resonator? I have also used a ceramic with 2 legs resonator at 4 mhz.
    In any case i will try to blink an led.
    As i mentioned on my previous posts, i have tried also the code from elektor, and works. (i just dont have the right sensor DS1820 which is very old and i dont get the right results. but i have something in the screen at least.
    With the code from Mr. Fratello, i dont have anything on the screen. That mean that there is something wrong, either with the hardware or software.
    Thank a lot again for your help.
    Dec 2008
    Ploiesti, ROMANIA
    The software it's ok !!! Remove the X-tal (leave pins 15 & 16 free), re-compile the code with added from post #73, check the RV1, check the connection to LCD., check the voltage (5 volts).
    Oct 2010
    ok thanks a lot fratello,
    please give me some time to do it in the afternoon.
    I have done something else with a completed different thermostat.
    please check for my from an other thermostat with an old ds1621, a friend of mine gave it me i can upload the code if you like. (really sorry for my Greeks at the video, i upload it for the AVCLUB.gr there is a sub forum for flashlights)
    The reason i put the video is to see the menu for the thermostat configuration. It is nice to see the configured temp and the real time temp at the same time.
    Please check the video at 2:12 for the configuration menu.
    Oct 2010
    there is something on the display now.
    thanks a lot. The problem now is that i dont have the right value for the temp.
    It appears a minus value for both INT and EXT sensor.
    also the values for the SET POINTs are only in minus values. I think the minus symbol appears on both 75 and -25. I will upload pictures later on.
    The values now i have are
    INT: -0.06
    EXT: -0.06
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
