Please help with code for DS18B20
Results 1 to 40 of 110
Threaded View
  1. #23
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for support !!!!
    First code (post #18) return this result : 28 CA C6 48 1 0 0 A7
    Second code (post # 22) return : CA C6 48 01 00 00
    In the code that I write now I use something like this :
    "Init1
    OWOut DQ, 1, [$55, $28, $FE, $DA, $3E, $0, $0, $C1, $4E, $FF, $FF, $7F]
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $48]
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $B8]
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $BE]
    Pause 1000
    OWOut DQ, 0, [Temperature.Byte0, Temperature.Byte1, 0, 0, DS18B20_12bit]
    Init2
    OWOut DQ, 1, [$55, $28, $FE, $DA, $3E, $0, $0, $C1, $4E, $FF, $FF, $7F] 'SENSOR 2 !!!!!!!!! not reading yet !!!!
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $48] 'SENSOR 2 !!!!!!!!! not reading yet !!!!
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $B8] 'SENSOR 2 !!!!!!!!!
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $BE] 'SENSOR 2 !!!!!!!!!
    Pause 1000
    Main
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $44] ' Start temperature conversion Sensor 1
    WaitLoop:
    While not DQ
    Wend
    OWIn DQ, 0, [Temperature.Byte0, Temperature.Byte1]
    GoSub Convert_Temp
    GoSub DisplayTemp
    Part2
    OWOut DQ, 1, [$55, $28, $CA, $C6, $48, $1, $0, $0, $A7, $44] ' Start temperature conversion Sensor 2
    WaitLoop2:
    While not DQ
    Wend"
    I hope it's good...will see !
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
