Yes sure, i will upload the code soon, and i will also make a small video if you want.
On the output, i have done the following configurations.
1) only an LED
2) light the LED through resistor.
3) light the LED through a transistor.
In case number 1. the 3MM LED does not go ON but it flashes very low with some pulses, it is not noticeable. (the 5 mm goes on)
In case number 2. the LED works just fine
In case number 3. the LED works just fine
My question is, if anyone understands why it does not light up straight from the PIC (pin) output with no transistor or resistor.
thanks a lot and sorry for the trouble
