Please help with code for DS18B20
Results 1 to 40 of 110
    Oct 2009
    Utah, USA
    Default Re: Please help with code for DS18B20
    but i need your advice according to the second sensor please.
    could you please help me out to finish the schematic?
    The second sensor (and the third, forth, fifth, etc, etc.) simply goes in parallel with the first... see example below.
    The PIC's job is to address each individual sensor to read its value. That is how the One-Wire bus works. Each sensor has an address and will only respond to it's address.
    Dwight
    Dec 2008
    Ploiesti, ROMANIA
    Yes. right !!! In my code I put the individual code of each sensor . For working with ANOTHER sensors, first you need to read the address of each sensor and then modify the code. You can find some examples on this forum...
    Oct 2010
    hello,
    thanks for the answer. i use the DS18B20, so i dont need to do any modification.
    The problem is that i cannot see anything on the display. It looks like something is really wrong inside the code.
    I think that i make the mistake on the code or the circuit above.
    1) does this schematic corresponds to the code? (i need to put one more sensor)
    2) do i need to do anything inside the code
    for example in the following lines do i need to chose one of these?
    ;DS18B20_9bit CON %00011111 ; 93.75ms, 0.5°C
    ;DS18B20_10bit CON %00111111 ; 187.5ms, 0.25°C
    ;DS18B20_11bit CON %01011111 ; 375ms, 0.125°C
    ;DS18B20_12bit CON %01111111 ; 750ms, 0.0625°C (default)
    DS18B20_1_12bit CON %01111111 ; 750ms, 0.0625°C
    ;DS18B20_2_12bit CON %01111111 ; 750ms, 0.0625°C
    But still i dont see anything on my lcd.
    Oct 2010
    To be more specific,
    as i understand i need to find the unique ID from each sensor and then modify it on the code.
    First i need to solve an other problem, what about i dont see anything on the display?
    Shouldnt i see some 'no sensor' or like that at least?
    Dec 2008
    Ploiesti, ROMANIA
    Yes, it's right what you say in post #71 !
    Put this in top of code :
    @ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON
    define osc 4
    REMOVE Xtal and caps (no need quartz precision) ; or keep it - but then replace "Intosc_osc_noclkout" with "XT_Osc".
    Now you MUST have something on display !
    Oct 2010
    i've tried it but nothing on the lcd again,
    i think it has to do with the osc commands and there is the problem.
    i put a 4mhz ceramic with two legs, i idid also tried the ceramic 4mhz with 3 legs. Nothing on the screen.
    i'm sad that cannot complete it.
    thanks a lot for your help! am i doing something wrong with the schematic? Do i need anything else?
    The code from the elektor works, but i dont have the ds1820. And it is on the screen xxx.xx
    But i dont understand why it does not work with your code.
    Aug 2010
    Maryland, USA
    First you need to prove the pic is running. There are no caps shown in above schematic at the xtal, do you have caps on it? Have you made a led blink? Did you try internal osc?
    From the quick skim I did on this thread, it seems I have read several posts claiming the code works. Time to look at your hardware.
    -Bert
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
