I am using a PIC 18F8722 micro to interface an older piece of equipment.
Here is the code I am using to test the proper read of some data:
The pic clock and the equipment clock are operating at different speeds, I think the pic is 2-4 times faster and not in sync with the equipment I am trying to interface to. The problem I have is that I cannot always read the data. I sometimes miss some of the correct conditions. Any thoughts?Code:while Counter1 <200 If PortA = $0B then Toggle PortB.0 endif If PortA = $0C then Toggle PortB.1 endif If PortA = $0D then Toggle PortB.2 endif Counter1=Counter1+1 wend
