TIMER1 or RCTIME?
Results 1 to 8 of 8
    Dec 2008
    Charlottesville, VA
    Hi, ...
    Let's see:
    sound speed @ 20°C ( SQR ( 1.4*287*(273+20)) = ~ 340 m/s
    say your min distance will be ~ 10 cm ... time will be 2x.1/340 ~ 600 µS
    RCTime @ 20 Mhz gives 2µS granularity ... for a 16 bits value
    so, the range will be 10 cm to 10cm* 65535/300 = 21.8 meters.
    Looks fine ...
    Thank you for your help. However, I am a little confused by your calculations. Could you explain them a little more for me? I understand your calculation for speed of sound as that is what I am already using. It's from there on that I am confused.
    Talking
    as your Tx and Rx will be on the same side, both facing the object to be detected ...
    sound will have a travel equal to ... Twice the distance you look for.
    As simple as that !
    2 x 10 cm / 340 m/s = ... 0.588 ms = ~ 600 µs
    10 cm mini ??? haha ... I let you discover why ... and why to cancel detections under these values ...
    Dec 2008
    Smile Your ROBOTICS Project
    Got some pictures of your ROBOT so we can see please ?
    Happy New Year 2009
    Robert.Quaas
    Dec 2008
    Charlottesville, VA
    Smile
    First of all I want to thank you all for your help.... I believe I have figured the RCTIME command out well enough that I have a fairly accurate distance measurement.
    Here is the section of my code. The only problem that I have is the fact that you can't use floats in Microcode studio, or if you can I don't know how. So some parts of my calculations may seem awkward but it will work right once finished.
    CHECK_RANGE:
    FOR B = 1 TO 50
    SPEED_OF_SOUND = 1126 'Speed of sound at 68 degrees F is 1125.79ft/s
    DEFINE PULSIN_MAX 4000 'Limits the count to an equivalent of about 8ms
    HIGH PORTB.0 'Used to drive a 555 timer which generates 40khz signal
    RCTIME PORTB.1, 1, RETURN_TIME 'How long before pin changes logic?
    RETURN_TIME = RETURN_TIME * 2 'Calculates total microseconds
    SPEED_OF_SOUND = SPEED_OF_SOUND * 12
    DISTANCE = (SPEED_OF_SOUND * (RETURN_TIME / 1000 / 1000)) / 2
    LCDOUT $FE, 1
    LCDOUT $FE, 2
    LCDOUT $FE, $0C
    LCDOUT "DISTANCE IS ", DISTANCE, "IN" '2 x 16 LCD Display by the way
    PAUSE 500
    NEXT B
    Now, by my calculations, using a 20MHz clock makes the resolution of the RCTIME command 2us. So by saying (return_time * 2), this multiplies the count returned by 2 us. At max range it would be 4000 * 2 or 8000us. Then, I want to measure the distance in inches so I multiply the speed of sound variable by 12 to convert to inches. Then for the distance calculation, and this is where my problem is. I cannot store a float in a variable, instead the result of the calculation will be stored with everything after the decimal cut off. But I can deal with that for now. I would like to know if it is possible to get the right side of the decimal stored into a variable though. So, at max range of 4000 counts, (13512 inches * (8000us/1000/1000 'to convert to seconds')) / 2 'cut the amount of time in half' = 54.048 inches to target. However, only 54 will be stored in the distance variable at the current time. So my range I think would show 0 inches to 54 inches. I don't intend to let the robot get close enough to return a number as low as 0 though. As for pictures, I will post some as soon as I can. Again, thank you all for your help and feel free to double check my work above.
  1. Software PWM using Timer1
    By muqasim in forum mel PIC BASIC Pro
    Last Post: - 18th December 2009, 12:49
  2. Help with TIMER1 + SLEEP
    By Yodoad in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 16:07
  3. Time Period of Timer1
    By arnol34 in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 01:31
  4. Timer1 and Interupt wierdness
    By mind in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2005, 02:24
  5. PULSIN and RCTIME
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 15:45
