Rescaling of values in PBP.
Results 1 to 8 of 8
    I think you guys have it backwards.
    You're turning a 0 into 165, he wants 165 to be 0.
    And it should be adjustable according to each devices calibration numbers. Constants in the formula can't do that.
    Here's a simple Y=mX + b type slope intercept.
    It's limited to byte values and Positive slopes, but it should do the job.
    DEFINE HSER_BAUD   9600 'Hser baud rate
    DEFINE HSER_CLROERR   1 'Hser clear overflow automatically
    DEFINE HSER_RCSTA   90h 'Hser receive status init
    DEFINE HSER_TXSTA   24h 'Hser transmit status init
    Value       VAR BYTE
    Result      VAR BYTE
    TempB       VAR BYTE
    CAL_Low     CON 165    ; These are the measurements from calibration
    CAL_High    CON 245
    Result_Low  CON 0      ; These are what the final range should be
    Result_High CON 254
    FOR Value = CAL_Low to CAL_High
       GOSUB Scale
       HSEROUT [DEC Value," = ",DEC Result,13,10]
    NEXT Value
    STOP
    Scale:
      TempB = (Value MAX CAL_Low) MIN CAL_High ; Limit Value to CAL range
      Result = ((TempB-CAL_Low)*(Result_High-Result_Low))/(CAL_High-CAL_Low)
    Which gives these results
    Value = Result
    165 = 0
    166 = 3
    167 = 6
    168 = 9
    169 = 12
    170 = 15
    171 = 19
    172 = 22
    173 = 25
    174 = 28
    175 = 31
    176 = 34
    177 = 38
    178 = 41
    179 = 44
    180 = 47
    181 = 50
    182 = 53
    183 = 57
    184 = 60
    185 = 63
    186 = 66
    187 = 69
    188 = 73
    189 = 76
    190 = 79
    191 = 82
    192 = 85
    193 = 88
    194 = 92
    195 = 95
    196 = 98
    197 = 101
    198 = 104
    199 = 107
    200 = 111
    201 = 114
    202 = 117
    203 = 120
    204 = 123
    205 = 127
    206 = 130
    207 = 133
    208 = 136
    209 = 139
    210 = 142
    211 = 146
    212 = 149
    213 = 152
    214 = 155
    215 = 158
    216 = 161
    217 = 165
    218 = 168
    219 = 171
    220 = 174
    221 = 177
    222 = 180
    223 = 184
    224 = 187
    225 = 190
    226 = 193
    227 = 196
    228 = 200
    229 = 203
    230 = 206
    231 = 209
    232 = 212
    233 = 215
    234 = 219
    235 = 222
    236 = 225
    237 = 228
    238 = 231
    239 = 234
    240 = 238
    241 = 241
    242 = 244
    243 = 247
    244 = 250
    245 = 254
    Oh craps, everyone's beaten me to it... my offering...
    OutputByte=(InputByte-165)*318/100
    This is calculated from...
    245-165=80 (the original span)
    254/80=3.175 (new span divided by old span)
    3.175 is rounded up to 3.18 and then we multiply it by 100 so as to keep everything an integer (which is why we finally do a divide by 100 to bring us back to reality).
    You may want to preceed the formula with...
    If InputByte<165 then InputByte=165
    If InputByte>245 then InputByte=245
    OMG Darrel... How much have you had to drink to think of that one?
    Sep 2008
    Stockholm
    I guess that this was more complicated than I first guessed
    ..Currently I'm building a better test-rig so I can do some serious testing, right now I guess I just put a LCD in it and display the values.
    The 165 and 245 was just typical values, I guess that the low value can be around 135-170 and the high one maybe 235-254. Maybe the span can be even larger.
    The idea is to have a calibrating sequence first when the pic is started, where I determine the max and min value for this time, and then use this until the next start, where its calibrated again.'
    Darrels solution was very neat btw
    Ha! Apparently not enough Eggnog yet. It worked on the first compile.
    Of course, I did an Ugly spreadsheet for the math first.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. PBP, ASM and LST files
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 12th January 2010, 14:43
  3. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 09:02
  4. Compiler differences between PBP 2.33 & 2.46
    Last Post: - 2nd May 2006, 20:01
  5. Newby- PBP wont compile for 18F (MPLAB)
    Last Post: - 18th December 2005, 00:30
