This is what i use to drive my 8 digit dual display
Hope it helps.
By adjusting f & f2 you can adjust the brightness...
'REV 071408 * #disdrive9.01 DISPLAY LED DRIVER
DEFINE OSC 20
DEFINE SER2_BITS 8
A VAR BYTE
B VAR BYTE
C VAR BYTE
F VAR BYTE
F2 VAR BYTE
DCP VAR BYTE
AMP VAR WORD
TIME VAR WORD
COUNTA VAR WORD
COUNTB VAR WORD
COUNTC VAR WORD
SNO1 VAR WORD
SNO2 VAR WORD
FLOW7 VAR PORTA.0
DAT7 VAR PORTA.1
SPF10 VAR PORTA.2
BURN VAR PORTA.3
SPF02 VAR PORTA.4
SPF03 VAR PORTA.5
SEGMENT VAR PORTB
DIGIT VAR PORTC
TRISA = %11111111
TRISB = %00000000
TRISC = %00000000
ADCON0 = %00000000
ADCON1 = %00000111
A = 0
C = 0
B = 0
F = 100
F2 = 3
DCP = 0
PAUSE 20
TIME = 1234
AMP = 5678
EEPROM 0,[129,243,73,97,51,37,5,241,1,49,254,253,251,247,239 ,223,191,253]
GOSUB BSEQ
LOOP: ' AND NOW THE MAIN EVENT
IF FLOW7 = 1 THEN
SerIN2 PORTA.1,84,[TIME.highbyte,TIME.lowbyte,AMP.highbyte,AMP.lowbyt e,DCP]
IF DCP = 9 THEN
GOSUB BSEQ
FOR C = 0 TO 4
READ TIME DIG C,SEGMENT
LOOKUP C,[$BF,$7F,$DF,$EF],DIGIT
IF C = 4 THEN
PORTB = %11111110
IF DCP = 1 THEN DIGIT = $EF
IF DCP = 2 THEN DIGIT = $DF
IF DCP = 3 THEN DIGIT = $7F
IF DCP = 4 THEN DIGIT = $BF
PAUSEUS f
PORTB = $FF
PORTC = $FF
PAUSEUS F2
NEXT C
FOR B = 0 TO 4
READ AMP DIG B,SEGMENT
LOOKUP B,[$FE,$FD,$FB,$F7],DIGIT
IF B = 4 THEN
PORTB = %11111110
IF DCP = 5 THEN DIGIT = $FE
IF DCP = 6 THEN DIGIT = $FD
IF DCP = 7 THEN DIGIT = $FB
IF DCP = 8 THEN DIGIT = $F7
PAUSEUS f
PORTB = $FF
PORTC = $FF
PAUSEUS F2
NEXT B
GOTO LOOP
BSEQ: FOR A=0 TO 3
FOR C = 0 TO 6
READ C+11,SEGMENT
LOOKUP A,[$EF,$DF,$7F,$BF],DIGIT
PAUSEUS 1000
PORTB = $FF
PORTC = $FF
PAUSE 10
NEXT C
PAUSE 2
NEXT A
FOR A=0 TO 3
FOR B = 6 TO 0 STEP -1
READ B+11,SEGMENT
LOOKUP A,[$FE,$FD,$FB,$F7],DIGIT
PAUSEUS 1000
PORTB = $FF
PORTC = $FF
PAUSE 10
NEXT B
PAUSE 2
NEXT A
DCP = 1
