DVD Player Remote Control
Results 1 to 5 of 5
    Default DVD Player Remote Control
    Good day
    Is it possible to design a DVD Player Remote control that will work on any DVD Player?
    Thank you
    Koossa
    Mar 2006
    Pennsylvania, USA.
    Koosa,
    Anything is possible, but it would be a lot of work. Almost every manufacturer uses different encoding, and while some of them are easy to find, you would have to do a lot of testing to get all of them.
    I have a few of Bruce's decoder chips, (Rentron Electronics,) that work great with Sony remotes, his website has a lot of information to get you started.
    Good Luck!
    Jerry
    If your oscilloscope costs more than your car...
    Thank you very much Jerry!!
    Hi Coossa,
    To get a PIC device to generate the control codes for multiple brands DVDs you first need to know the necessary codes. The best way to get them will be if you have your target manufacturers remotes and use them to identify your codes or….
    Just to get you started I suggest to get yourself one of the Universal remotes which are quite inexpensive and can, by changing a manufacturer code, control different manufacturers devices (TVs, VCRs, DVDs etc….).
    Also you need to setup one of your computer audio inputs with an infrared receiver to record incoming signals from the remote like it has been discussed in this forum (see Dave Huston site at http://davehouston.org/learn.htm for more information).
    I used this method few years ago to build a simple ON / OFF TV remote control and it worked really well for me.
    Nick
    Thank you very much Nick!
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. Newbie remote control question?
    By Clodoaldo in forum mel PIC BASIC Pro
    Last Post: - 14th July 2009, 18:20
  3. IR Remote Control Issues
    By Kamikaze47 in forum mel PIC BASIC Pro
    Last Post: - 28th August 2007, 15:12
  4. No one-way approach to learning ir remote control frequencies
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 14:26
  5. Remote control
    By Radiance in forum General
    Last Post: - 6th August 2003, 16:13
