need help for measuring two freq at same time
Results 1 to 4 of 4
    Perth, Australia
    you could try using the "change on portb" interrupt. put both of the inputs on port b and then any change will trigger the interrupt. You could set up the interrupt handler to figure out which one has changed and using a timer and a bit of maths, work out both frequencies.
    This is like super-crude... but it'll kinda work as a starting point...
    	InputA var PortB.0
    	InputB var PortB.1
    	LED var PortB.4
    	Temp var Byte
    	ToggleA var Temp.0
    	ToggleB var Temp.1
    	CounterA var WORD
    	InputACount var WORD
    	InputBCount var WORD
    	TRISB=%00001111
    Start:
    	'	Get Ready
    	ToggleA=0
    	ToggleB=0
    	InputACount=0
    	InputBCount=0
    	High LED		' We're Ready...
    	'	Start Count
    	For CounterA=0 to 3999
    		If (InputA=0 and ToggleA=0) then ToggleA=1
    		If (InputA=1 and ToggleA=1) then
    			InputACount=InputACount+1
    			ToggleA=0
    		If (InputB=0 and ToggleB=0) then ToggleB=1
    		If (InputB=1 and ToggleB=1) then
    			InputBCount=InputBCount+1
    			ToggleB=0
    		PauseUS 250
    		Next CounterA
    	'	Stop Count
    	Low LED
    	LCDOut $FE,1,"A=",#InputACount,"Hz"
    	LCDOut $FE,$C0,"B=",#InputBCount,"Hz"
    	Goto Start		' Loop forever
    Yes, of course there are limitations... you'll have to trim PauseUS so that the For/Next Loop is exactly 1 second long... so put a scope on the LED pin... another limitation is that your Pulse must be wider than about 270uS so you may need some external circuitry... another is that probably 3.5kHz is a practical maximum count... but go play...
    Mar 2007
    Mumbai-INDIA
    Smile
    Hi Melanie & kamikaze47,
    First of all New year Greetings to you. Thanks for replying and giving me helping hand.
    Actually 2 Months back I purchased Cheap 100cc new motorcycle, which doesnt have RPM meter, so I wanted to make RPM meter and Speedometer for my bike. I am getting RPM signals from Spark plug and and Speedometer signal from hall sensor, which is just few hundred hz per seconds, but problem was how to measure both signals at same time.
    Melanie, I will try your code, I will try not to bother you and use my small brain to its max.
    Thank you once again,
    regards
    Mahesh-VU2IIA
    my hobby page, if you have time to see.
    http://www.vu2iia.bravehost.com/
  1. I don't understand this code!
    Last Post: - 13th February 2008, 03:55
  2. Measuring time
    By AugustoPedrone in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 00:46
  3. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 20:55
  4. Alarm Time
    By Santana in forum Code Examples
    Last Post: - 8th December 2006, 14:58
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 15:24
