I tryed to do the sound card version today byt no one of my 2 computers have a "Line in" or "Audio in" input, only a input with a microphone symbol on and that doesīt work.
I have now posted the code in the code exampel area now.
Is it posible to capture the RF signal with the PICkit2 tool "PICkit 2 Programmer Logic Tool Analyzer"?
If so i will buy the PICkit2 programmer (i need a new programmer with USB support.)
http://www.microchip.com/stellent/id...cName=en023805
You still might be able to use the mic input, if you attenuate the signal 1:1000 (a 100K and a 100ohm resistor divider, perhaps?). The waveform might not look picture perfect, but will surely be good enough for your purpose.
Alternately, if you have a serial port, you might want to look at Dante's infrax utility at http://www.geocities.com/tdanro/irman/irman.html
This would require you to build a small capture circuit, and be informed this does not work reliably with USB-to-serial interfaces. On a native serial port (or a PCI based additional one) it works quite brilliantly.
Anand
Ok, i will try.
But i still need a new programmer so i hope that i can use the "Logic Tool" in Pickit2, or doesīt that work?
The mic input is tricky. Usually, it has +5V on one conductor to power electret microphones. Some are stereo.A logic analyzer might work but I've never tried one. The signals typically are between 1000Hz & 2000Hz.
