PIC to control NEXA remoteswitch
Results 1 to 22 of 22
    Jan 2008
    Yes i want to control it from the Parallax transmitter.
    And yes the protocol seems to look like the X10 but there are some diffrents becouse the X10 funtion in PBP doesīt work.
    And the assembly code posted above . . where did it come from, and do you have the include file system.inc? the other one I think comes from MPASM.
    The web pages I visited list these for sale in Swedish speaking countries only. I think these are over my head, sorry.
    Seeing the actual original signal would make it much easier, right?
    Use the original transmitter, and a compatible RF receiver; feed the output to the soundcard and capture this signal, and study it using any sound editor (Audacity / Goldwave) (more details on this technique at Dave Houston's site).
    It would then be much easier to replicate this signal.
    Anand
    Dec 2005
    Here's the URL that Anand referred to...Once you capture the codes you merely need to duplicate the timing with your transmitter.
    Try something like this.
    ' Timing as described in NexaProtocol.txt
    T CON 350      ' T = 350uS
    T3 CON 1050    ' 3T
    T32 CON 11200  ' 32T (Stop/Synch)
    ' Note we're using 1 VS X as shown in text
    A1_ON  CON %101100000000 ' 12-bit code for House/Unit A1 ON
    A1_OFF CON %001100000000 ' 12-bit code for House/Unit A1 OFF
    '           ||||||||||||____ 4-bit House code
    '           ||||||||________ 4-bit Unit code
    '           ||||____________ 3-bit Unknown code
    '           |_______________ 1-bit Activation code 1=ON 0=OFF
    D_PACKET VAR WORD ' Holds 12-bit data packet to send
    INDEX VAR BYTE    ' Data packet bit index pointer
    LOOPS VAR BYTE    ' Loop counter
    TX VAR PORTB.0    ' Connects to RF transmitter data in
    LOW TX            ' TX output idles low for RF carrier OFF
        D_PACKET = A1_ON
        GOSUB Send
        PAUSE 5000
        D_PACKET = A1_OFF
        GOSUB Send
        PAUSE 5000
        GOTO Main
    Send:
        FOR LOOPS = 1 TO 4    ' send each packet 4 times
          FOR INDEX = 0 TO 11 ' sends 12 bits per pass LSB 1st
            HIGH TX           ' The 1st half of a 0 or X  bit period is the
            PAUSEUS T         ' same so no need to repeat this sequence inside
            LOW TX            ' the IF block
            PAUSEUS T3
            IF D_PACKET.0[INDEX]=1 THEN
               HIGH TX        ' send a 1 bit (1=X here)
               PAUSEUS T3
               LOW TX
               PAUSEUS T
               HIGH TX        ' send a 0 bit
               PAUSEUS T
               LOW TX
               PAUSEUS T3
          NEXT INDEX          ' loop until all 12-bits sent
          ' Start of Stop/Synch period after each 12-bit packet
          HIGH TX
          PAUSEUS T
          LOW TX
          PAUSEUS T32
          ' End of Stop/Synch period
        NEXT LOOPS        ' send 4 packets per pass
    Can't say if this works or not since I don't have the receiver to play with, but it looks close
    to what's shown in the NexaProtocol.txt timing diagram.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2008
    Hi Bruce
    Thanx for the code, but it doesīt work so good but we are close now.
    If i have the NEXA switch ON and let the PIC program running for 1 - 5 minutes the PIC turns the NEXA off, but never on again.
    Here is more information for the NEXA and source code in some other language..
    http://svn.telldus.com/svn/rf_ctrl/t...runk/examples/
    I have read on a swedish forum that the original NEXA remote control sendīs 25 bits but there is only every second bit that contains the data, it sends a "zero" between every bit
    http://elektronikforumet.com/forum/v...ht=nexa+proto*
    Hi Fredrick,
    I think I goofed on the 3-bit unknown bits. Try changing to this;
    A1_ON CON %111000000000 ' 12-bit code for House/Unit A1 ON
    A1_OFF CON %011000000000 ' 12-bit code for House/Unit A1 OFF
    -Bruce
    tech at rentron.com
    Dec 2005
    If you capture the codes as Anand suggested, I think you will find they are substantially different from what is described in NexaProtocol.txt. The Elro AB600 and Intertechno are among those that use the Arc Technology hardware. Those protocols agree with NexaProtocol.txt as far as A=0000, 1=0000, etc. but the wave shapes differ significantly from the shapes in NexaProtocol.txt. As I recall, the codes I have for Elro AB600 and Intertechno tested OK using a European Pronto (433.92MHz) to send the RF codes.
  1. Control NEXA 230V RF Switch
    By Fredrick in forum Code Examples
    Last Post: - 7th December 2009, 00:19
  2. Replies: 5
    Last Post: - 12th September 2007, 16:59
  3. Motor Control PLC with a PIC
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2006, 08:59
  4. Pic Control With Software
    By Agent36 in forum General
    Last Post: - 18th October 2006, 19:18
  5. Need help on pic to pic flow control (simple problem I think)
    By khufumen in forum mel PIC BASIC Pro
    Last Post: - 11th January 2006, 01:34
