4x3 keypad and an LCD.. need help.
Results 1 to 23 of 23
    In this case the decimal needs moved three places to the right.
    26/21=1.238095...
    1000*26/21=1238.095...
    x = (1000*26/21)//1000
    x=238
    You could have
    y=26
    x = (1000*y/21)//1000
    The above will only work if "y" is an integer 22 through 41.
    When reading a sensor the range of values are fixed so with a little imagination a constant like in the above case 1000 will work. When another application comes along with a different set of values a different constant and equation will be required.
    What is your application besides a keypad?
    Quote Originally Posted by mackrackit
    You could have
    y=26
    I'm not sure why any value 0 - 65 will not satisfy your equation. The only requirement to keep it "legal" is to keep 1000*y under 65535. Also if you can afford to loose one digit after the decimal point (0.00x) then the range for y will be 0 – 650.
    I guess knowing more about the application will help make the best decision.
    Nick
    Quote Originally Posted by Nicmus View Post
    Nick
    I should have said 2 - 41 .
    Beyond these values you run into the leading zero problem with the equation I gave.
    Some values above 41 will work, some will return 0.0xx. The 0 tenths is the problem.
    Thanks for catching that.
    Wink
    Hi, Taisen
    Is this little calculator to count what you'll get this year ???
    http://www.piratekingonline.com/foru...earchid=836105
    Seriously ... you should turn to a 16Bits core device ( 18F452 i.e.) and use the 32 bits calculations of PBPL ...
    Hi mackrackit,
    If the leading zeros are a problem you just use DEC 3 in your LCDOUT command and you should be OK on full 0 – 65 range. The only change will be with the result of y/21 (0 -6).
    nick
    Hi mackrackit,
    nick
    Yep. We really need to know what taisen83 is trying to do.
    If all of the sudden the numbers change to something like
    x = (1000*1/3000)//1000
    Then it all falls apart, I tink
    PBL is the ticket.
    Dec 2008
    currently im doing a rice dispenser device that accepts a weight or price value.. my problem was at the price input value.. as the device runs it will ask for a price/kilo of the rice.. assuming i input a value of 25.50, but the actual value stored is 2550. this 2550 is the reference for determining the weight to be dispensed. after 2550 stored, the program ask for another input to be compared in the 2550. i used the codes that mackrackit posted.
    'variable PRICE is the reference input
    'TOTALAMOUNT is the variable to be compared
    PRICED = PRICE/10
    AMT = TOTALAMOUNT/10
    DECIKILO = (100*AMT/PRICED)//100
    WHOLEKILO = (100*AMT/PRICED)/100
    LCDOUT $FE,$C0,#WHOLEKILO,".",#DECIKILO," Kg"
    using this the program I can determine the weight but it only accepts 4 digit number.. making it to a 5 digit input will go beyond a 65535 limit.
    If you have PBP 2.50 and use a 18F
    chip, you can compile with PBPL
    that will give you 32 bit math.
    This will give you the ability to use
    numbers with a range of
    -2147483648 to
    +2147483647
    That should solve the problem.
