Voice Playback CHIP SD20
Results 1 to 20 of 20
    You're Welcome Pedro,
    Hope you (and everyone else) had a Happy "Boxing Day"!
    Dec 2008
    Thumbs up SD20 Voice Chip
    Hi Darrel
    Thanks for help of this. I finally got it working, the engineer from the manufacturer found a small bug in their chip firmware. So anyone interested in using this chip should increase the reset time and increase the time for playback also.
    See the amended code here :
    @ DEVICE XT_OSC,MCLR_OFF,LVP_OFF,WDT_OFF,PROTECT_OFF
    DEFINE LOADER_USED 1
    ' ** Setup the Resonator Frequency, in Mhz **
    Define OSC 4
    Baud con 84 ' 9600 baud rate
    ' ** Port configurations **
    TX VAR PORTB.5
    RX VAR PORTB.2
    CLK VAR PORTA.4
    DI Var PORTA.0
    RESET VAR PORTB.6
    PIEZO VAR PORTB.7
    DAT VAR WORD
    Idx VAR BYTE
    counter var byte
    volume var word
    volume = 65527
    Init:
    ANSEL = 0 'Configure all pins to digital operation since not using ADC
    CMCON = 7 ' disable comparators
    begin:
    low piezo
    dat = $FFF7
    serout2 tx,baud,["Voice Volume - 1st Data = ",bin16 dat,13,10]
    GOSUB SendDat
    dat = $4
    ' set counter to file no. 4
    counter = 4
    serout2 tx,baud,["Address 4 of voice file - 2nd Data = ",bin16 dat,13,10]
    GOSUB SendDat
    playaddr:
    dat = $fffe
    serout2 tx,baud,["Play/Pause - 3rd Data = ",bin16 dat,13,10]
    ' GOSUB SendDat
    GOSUB Playdata
    switch:
    'if porta.2=0 then
    ' counter = counter - 1
    ' if counter<=1 then counter = 2
    ' dat = counter
    ' serout2 tx,baud,["Address of voice file - 2nd Data = ",bin16 dat,13,10]
    ' GOSUB SendDat
    ' goto playaddr
    'endif
    if porta.1=0 then
    counter = counter + 1
    if counter>=7 then counter = 6
    dat = counter
    GOSUB SendDat
    goto playaddr
    ' Reduce Volume
    if porta.2=0 then
    volume = volume - 1
    if volume<=65520 then volume = 65527
    dat = volume
    serout2 tx,baud,["Address of voice volume = ",bin16 dat,13,10]
    GOSUB SendDat
    'goto playaddr
    goto switch
    STOP
    SendDAT:
    LOW RESET ; 5ms reset pulse
    PAUSE 5
    INPUT RESET
    PAUSE 300 ; 300ms before data
    For Idx = 15 to 0 STEP -1 ; loop thru the bits
    LOW CLK ; set CLK LOW
    IF dat.0(Idx) THEN
    INPUT DI ; if bit = 1 then INPUT, not HIGH
    LOW DI ; if bit = 0 then LOW
    PAUSE 1 ; data settle time
    INPUT CLK ; clks data on rising edge
    PAUSE 1 ; data read time
    NEXT Idx ; do rest of the bits
    INPUT DI ; leave data line tri-stated
    Playdata:
    PAUSE 5
    INPUT RESET
    PAUSE 1250 ; 300ms before data
    IF dat.0(Idx) THEN
    All the best; Happy NEW Year !!!
    Wow, you have to wait 1-1/4 seconds after the reset.
    That's quite a "Bug".
    Especially since the datasheet says ...
    1 second after reset , if no action to the module, the chip will be into standby status within one second if no action after reset.
    Well, at least it works!
    Happy NEW YEAR!
    Dec 2008
    Wink SD 20 Voice Play Chip
    Thanks Darrel for your help.
    All the best and Happy New Year
    Robert Quaas
  1. isd4002 problems help required please
    By Agent36 in forum mel PIC BASIC Pro
    Last Post: - 29th March 2012, 07:57
  2. Trouble with PIC16F88 (chip hangs up)
    By nobner in forum mel PIC BASIC Pro
    Last Post: - 20th January 2009, 10:23
  3. TV Display Chip
    By zadok in forum mel PIC BASIC Pro
    Last Post: - 17th April 2008, 23:17
  4. ISD4003 & 16F877 Interface
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 26th December 2006, 18:50
  5. chip selection aid
    By PICMAN in forum General
    Last Post: - 21st February 2005, 19:33
