Voice Playback CHIP SD20
Results 1 to 20 of 20
Threaded View
  1. #4
    Dec 2008
    Default Voice Play Chip - SD20 - Construction Circuit.
    Here is a photo of my test circuit. Refer to page 22 from PDF document.
    Resistor network connected to CLK and DI pin in SD20 from PIC as follows:
    PortA.4
    10K
    10K
    |------ CLK - SD20 - P04
    10K
    Gnd
    PortA.0
    10K
    10K
    |------ DI - SD20 - P05
    10K
    Gnd
    Code as follows; but can not get it to work; any help PLEASE ?????
    @ DEVICE XT_OSC,MCLR_OFF,LVP_OFF,WDT_OFF,PROTECT_OFF
    DEFINE LOADER_USED 1
    Include "Modedefs.Bas"
    ' ** Setup the Resonator Frequency, in Mhz **
    Define OSC 4
    ' DEFINE SHIFT_PAUSEUS 100
    ANSEL = 0 'Configure all pins to digital operation since not using ADC
    '(Analog to Digital Converter)
    Baud con 84 ' 9600 baud rate
    ' ** Port configurations **
    TX VAR PORTB.5
    RX VAR PORTB.2
    CLK VAR PORTA.4
    DI Var PORTA.0
    PIEZO VAR PORTB.7
    DAT VAR word
    Init:
    TRISA=%11111111 ' Set PortA TRIS register
    TRISB=%00000000 ' Set PortB TRIS register
    begin:
    low piezo
    high CLK
    high DI
    dat = $FFF7
    serout2 tx,baud,["1st Data = ",bin16 dat,13,10]
    Shiftout DI, CLK, 1,[dat/16]
    dat = $3
    serout2 tx,baud,["2nd Data = ",bin16 dat,13,10]
    dat = $fffe
    serout2 tx,baud,["3rd Data = ",bin16 dat,13,10]
  1. isd4002 problems help required please
    By Agent36 in forum mel PIC BASIC Pro
    Last Post: - 29th March 2012, 07:57
  2. Trouble with PIC16F88 (chip hangs up)
    By nobner in forum mel PIC BASIC Pro
    Last Post: - 20th January 2009, 10:23
  3. TV Display Chip
    By zadok in forum mel PIC BASIC Pro
    Last Post: - 17th April 2008, 23:17
  4. ISD4003 & 16F877 Interface
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 26th December 2006, 18:50
  5. chip selection aid
    By PICMAN in forum General
    Last Post: - 21st February 2005, 19:33
