Voice Playback CHIP SD20
Results 1 to 20 of 20
    Dec 2008
    Question Voice Playback CHIP SD20
    Recently purchased a voice chip called SD20; Here is my code for PIC16F88, can not seem to get it to work.
    If you look at page 12,13; and page 20 for info.
    Attached is part of the datasheet document pages 1-13, I will post others up due to size limits.
    appreciate some help on this ......
    @ DEVICE XT_OSC,MCLR_OFF,LVP_OFF,WDT_OFF,PROTECT_OFF
    DEFINE LOADER_USED 1
    Include "Modedefs.Bas"
    ' ** Setup the Resonator Frequency, in Mhz **
    Define OSC 4
    ' DEFINE SHIFT_PAUSEUS 100
    ANSEL = 0 'Configure all pins to digital operation since not using ADC
    '(Analog to Digital Converter)
    Baud con 84 ' 9600 baud rate
    ' ** Port configurations **
    TX VAR PORTB.5
    RX VAR PORTB.2
    CLK VAR PORTA.4
    DI Var PORTA.0
    PIEZO VAR PORTB.7
    DAT VAR word
    Init:
    TRISA=%11111111 ' Set PortA TRIS register
    TRISB=%00000000 ' Set PortB TRIS register
    begin:
    low piezo
    high CLK
    high DI
    dat = $FFF7
    serout2 tx,baud,["1st Data = ",bin16 dat,13,10]
    Shiftout DI, CLK, 1,[dat/16]
    dat = $3
    serout2 tx,baud,["2nd Data = ",bin16 dat,13,10]
    dat = $fffe
    serout2 tx,baud,["3rd Data = ",bin16 dat,13,10]
    Last edited by robert.quaas; - 22nd December 2008 at 16:16. Reason: Upload PDF document Pages 1 - 13
    Dec 2008
    Default Voice Playback Chip - SD20
    Attached Pages from datasheet 14-20.
    Dec 2008
    Attached last of datasheet info: pages 21-26
    Dec 2008
    Default Voice Play Chip - SD20 - Construction Circuit.
    Here is a photo of my test circuit. Refer to page 22 from PDF document.
    Resistor network connected to CLK and DI pin in SD20 from PIC as follows:
    PortA.4
    10K
    10K
    |------ CLK - SD20 - P04
    10K
    Gnd
    PortA.0
    10K
    10K
    |------ DI - SD20 - P05
    10K
    Gnd
    Code as follows; but can not get it to work; any help PLEASE ?????
    Define OSC 4
    TX VAR PORTB.5
    RX VAR PORTB.2
    CLK VAR PORTA.4
    DI Var PORTA.0
    PIEZO VAR PORTB.7
    DAT VAR word
    Init:
    begin:
    low piezo
    high CLK
    high DI
    dat = $FFF7
    dat = $3
    dat = $fffe
    Dec 2008
    Default Voice Playback Chip SD20 *** Cannot anyone answer this ??? ****
    I have posted up my code and datasheets for reference but no one has any ideas ???? as yet ????
    Please let me know if anyone can help me ??
    Quote Originally Posted by robert.quaas View Post
    Can you be more specific? What do you mean it is not working, will it do nothing at all ? I notice you are trying to use PortA as digital, Have you disabled the comparators? Hint CMCON = ? Good idea to make it do a little dance before settling in to do serious work, like a heartbeat LED, just so you know life exists, helps keep from banging your head on the keyboard. That way you know the PIC is working but not as expected. you need to set ADCON register on this chip too.
    Dec 2008
    Default SD20 Voice Playback chip
    I have disabled the Comparators; and All PortA pins are digital.
    ANSEL = %00000000 ' PortA pins all digital
    ADCON0 = %00000000
    CMCON = 7 ' Turn off comparators(All digital)
    When I say it is not working. It sends the data; but does not playback. I hear a few clicks and that is it.
    What am I doing wrong here ???
    ADCON0 = %00000000
    I am guessing the data you are shifting out is somehow invalid. You are serial outputing data of nearly 2 full bytes, right? Is that what the module requires? I could not make that from that "data sheet". Please allow me to ask, does the module work if you switch it manually as in the schematic, by grounding p05? I feel like the data sheet is inadequate in it's detail as to how th control it with a microcontroller, it looks like p05 is the play button, P04 is clock(but for what) and P02 and p03 are to switch the wavs played, maybe it will spi control or not the way they show it. BTW do you have the SD card with appropriately named wavs programmed into it, installed? <font color=red>Where can get 1 of these to play with?</font color>
    Dec 2008
    Default SD20 Voice Playback Module
    The updated code is as follows:
    Define OSC 4
    'DEFINE SHIFT_PAUSEUS 100
    ADCON0 = %00000000
    TX VAR PORTB.5
    RX VAR PORTB.2
    CLK VAR PORTA.4
    DI VAR PORTA.0
    RESET VAR PORTB.6
    PIEZO VAR PORTB.7
    DAT VAR word
    Init:
    begin:
    low piezo
    HIGH RESET
    high CLK
    high DI
    LOW RESET
    PAUSE 5
    HIGH RESET
    PAUSE 300
    LOW RESET
    dat = $FFF7
    Shiftout DI, CLK,MSBFIRST,[dat/16]
    dat = $3
    dat = $fffe
    It clicks and does not play; do you think I have the timing correct as per the diagram from the datasheet ?
    Pedro Pinto's Avatar
    Pedro Pinto Guest
    Hello robert.quaas
    I'm interesting in this chip to. If i can understand, the chip can playback mp3 and wav files, is this correct? and you can connect it directly to a sd card, right?
    Must i order directly from china manufacturer or exists in Europe a supplier?
    Thanks for any information
    fsantos at ses-electronic.com
    Best regards
    Pedro
    LOW RESET
    PAUSE 5
    HIGH RESET
    PAUSE 300
    LOW RESET
    The second LOW RESET keeps the device in RESET during the transfer, it should not be there.
    The CLK rate of SHIFTOUT is 50khz or higher, but the device is expecting no more than 500 hz clk (2ms per bit).
    To slow it down, add ...
    DEFINE SHIFT_PAUSEUS 2000
    PortA.4
    10K
    10K
    10K
    Gnd
    Your voltage divider is only supplying 1.6V to the inputs (when High), and All inputs to the WTV020-SD-16P have internal Pull-up resistors of unknown value. So when the PIC's output is low the 10K resistor will be fighting the pull-up and probably doesn't go low enough.
    A better way would probably be to not use SHIFTOUT and send each bit and clk in a FOR loop. Then you can use LOW and INPUT and remove the voltage dividers completely. Just remember, NEVER use HIGH or SHIFTOUT or TRIS when directly connected.
    Jul 2006
    Hello Darrel
    Have you a code example how to do that with the For / Loop
    For beginners it helps a lot
    Pedro
    Sure, maybe something like this...
    Define OSC 4
    TX    VAR PORTB.5
    RX    VAR PORTB.2
    CLK   VAR PORTA.4
    DI    Var PORTA.0
    RESET VAR PORTB.6
    PIEZO VAR PORTB.7
    DAT VAR WORD
    Idx VAR BYTE
    Init:
      CMCON = 7 ' disable comparators
    begin:
      low piezo
      dat = $FFF7
      GOSUB SendDat
      dat = $3
      GOSUB SendDat
      dat = $fffe
      GOSUB SendDat
    STOP
    SendDAT:
      LOW RESET                    ; 5ms reset pulse
      PAUSE 5
      INPUT RESET
      PAUSE 300                    ; 300ms before data
      For Idx = 15 to 0 STEP -1    ; loop thru the bits
        LOW CLK                    ;   set CLK LOW
        IF dat.0(Idx) THEN
          INPUT DI                 ;   if bit = 1 then INPUT, not HIGH
          LOW DI                   ;   if bit = 0 then LOW
        PAUSE 1                    ;   data settle time
        INPUT CLK                  ;   clks data on rising edge
        PAUSE 1                    ;   data read time
      NEXT Idx                     ; do rest of the bits
      INPUT DI                     ; leave data line tri-stated
    Jul 2006
    Hello Darrel
    Thank you for the sample
    Can you explain this?
    is this correct?
    IF dat.0(Idx) THEN
    why not
    IF dat(Idx) THEN
    dat is a word variavel, so if
    in the loop at the moment
    idx is say 1 then it's the same like
    dat.1, that is the second bit of the word, or not
    NEXT Idx
    Thanks and best regards
    Pedro
    Quote Originally Posted by Pedro Santos View Post
    Can you explain this? ...
    IF dat.0(Idx) THEN ...
    I can.
    But since Melanie's already covered the subject, I'll let her.
    Bits, Bytes Words and Arrays
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    Jul 2006
    Thanks again Darrel
    Pedro
    You're Welcome Pedro,
    Hope you (and everyone else) had a Happy "Boxing Day"!
    Dec 2008
    Thumbs up SD20 Voice Chip
    Hi Darrel
    Thanks for help of this. I finally got it working, the engineer from the manufacturer found a small bug in their chip firmware. So anyone interested in using this chip should increase the reset time and increase the time for playback also.
    See the amended code here :
    Define OSC 4
    TX VAR PORTB.5
    RX VAR PORTB.2
    CLK VAR PORTA.4
    DI Var PORTA.0
    RESET VAR PORTB.6
    PIEZO VAR PORTB.7
    DAT VAR WORD
    Idx VAR BYTE
    counter var byte
    volume var word
    volume = 65527
    Init:
    begin:
    low piezo
    dat = $FFF7
    serout2 tx,baud,["Voice Volume - 1st Data = ",bin16 dat,13,10]
    GOSUB SendDat
    dat = $4
    ' set counter to file no. 4
    counter = 4
    serout2 tx,baud,["Address 4 of voice file - 2nd Data = ",bin16 dat,13,10]
    GOSUB SendDat
    playaddr:
    dat = $fffe
    serout2 tx,baud,["Play/Pause - 3rd Data = ",bin16 dat,13,10]
    ' GOSUB SendDat
    GOSUB Playdata
    switch:
    'if porta.2=0 then
    ' counter = counter - 1
    ' if counter<=1 then counter = 2
    ' dat = counter
    ' serout2 tx,baud,["Address of voice file - 2nd Data = ",bin16 dat,13,10]
    ' GOSUB SendDat
    ' goto playaddr
    'endif
    if porta.1=0 then
    counter = counter + 1
    if counter>=7 then counter = 6
    dat = counter
    GOSUB SendDat
    goto playaddr
    ' Reduce Volume
    if porta.2=0 then
    volume = volume - 1
    if volume<=65520 then volume = 65527
    dat = volume
    serout2 tx,baud,["Address of voice volume = ",bin16 dat,13,10]
    GOSUB SendDat
    'goto playaddr
    goto switch
    STOP
    SendDAT:
    PAUSE 5
    INPUT RESET
    IF dat.0(Idx) THEN
    Playdata:
    PAUSE 5
    INPUT RESET
    PAUSE 1250 ; 300ms before data
    IF dat.0(Idx) THEN
    All the best; Happy NEW Year !!!
    Wow, you have to wait 1-1/4 seconds after the reset.
    That's quite a "Bug".
    Especially since the datasheet says ...
    1 second after reset , if no action to the module, the chip will be into standby status within one second if no action after reset.
    Well, at least it works!
    Happy NEW YEAR!
    Dec 2008
    Wink SD 20 Voice Play Chip
    Thanks Darrel for your help.
    All the best and Happy New Year
    Robert Quaas
  1. isd4002 problems help required please
    By Agent36 in forum mel PIC BASIC Pro
    Last Post: - 29th March 2012, 07:57
  2. Trouble with PIC16F88 (chip hangs up)
    By nobner in forum mel PIC BASIC Pro
    Last Post: - 20th January 2009, 10:23
  3. TV Display Chip
    By zadok in forum mel PIC BASIC Pro
    Last Post: - 17th April 2008, 23:17
  4. ISD4003 & 16F877 Interface
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 26th December 2006, 18:50
  5. chip selection aid
    By PICMAN in forum General
    Last Post: - 21st February 2005, 19:33
