Can a line label be aliased to a VAR?
Results 1 to 3 of 3
    Nov 2007
    West Covina, CA
    Default Can a line label be aliased to a VAR?
    I'm working on a program using PBP2.47 that would have me repeating sub-routines for multiple input conditions and wondered if it were "allowable" to:
    • Alias a VAR to a line label, or
    • Assign a temporary variable name to a previously defined VAR
    My direction was this:
    Monitor two digital inputs then react upon a change and assign a variable name to the detected input variable.
    Scan two other inputs (switch setting) and assign a temporary variable name to VAR Mode.
    Here's a snipet of the code that shows my intentions but falls short of compiling.
    Start:
    ' Turn OFF timer and clear registers
        T1CON.0 = 0         ' Turn off TMR1
        TMR1H = 0           ' Clear TMR1 high byte counter
        TMR1L = 0           ' Clear TMR1 low byte counter
        T1CON = 48          ' Prescaler set to 1:8, and timer OFF
    While (lts = 0) and (rts = 0): wend
        pause 10            ' Debounce time
        gosub time1         ' Start timer and come back
        if (lts = 0) and (rts = 0) then start  'False switch, go back and wait
        if (lts = 1) and (rts = 1) then start  'Hazard lights ON, go back
    ' Check mode select switch position and assign Mode variable
        if (msel2 = 0) and (msel3 = 0) then md = 1
        if (msel2 = 1) and (msel3 = 0) then md = 2
        if (msel2 = 0) and (msel3 = 1) then md = 3
            if md = 1 then
                mode = timed    ' Mode now this label
            if md = 2 then
                mode = fixed1   ' Mode now this label
            if md = 3 then
                mode = fixed2   ' Mode now this label
    ' Check which side activated and assign side variables
        if lts = 1 then sd = 1
        if rts = 1 then sd = 2
            if sd = 1 then
                Side_brake = lrl     ' Side_brake assigned to this VAR
                side = lts           ' Side assigned to this VAR
            if sd = 2 then
                side_brake = rrl
                side = rts
    goto start
    This way one sub-routine can be performed using the "inserted" variable names, such as:
    i = 0
    HIGH side_brake        ' side_brake previously assigned to certain output
    FOR i = 1 to 3
    PULSOUT side, "x time"   ' side previously assigned to certain output
    GOSUB ChecknSee     ' Monitor inputs during OFF period and return
    NEXT i
    LOW side_brake
    I'm hoping I'm doing something feasible but needed someone's help in case I'm close or to stop me before I spiral out of control with an exercise in futility.
    Thanks in advance...
    Louie
    Sep 2003
    Vermont
    The simple answer is no. It looks like you cane rewrite this using "select case", and choose the goto destination accordingly.
    Ron
    Nov 2007
    West Covina, CA
    Thank you Ron,
    I'll research the Select/Case usage.
    Sometimes I feel I'm over looking something and get caught up in a paralysis of analysis when trying to be efficient about the whole thing.
    Louie
  1. RF Modules
    By tonyfelloni in forum mel PIC BASIC Pro
    Last Post: - 26th June 2010, 18:42
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
  4. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 12:47
  5. 18F6680 and portd problems.
    By jkbh in forum mel PIC BASIC Pro
    Last Post: - 6th June 2005, 11:54
