Originally Posted by
skimask
First off, why not trying to type a bit slower or something, maybe add something like punctuation. Makes it just that much easier for the rest of us to read.
Second...You might want to try and write out exactly what you want your 'buttons' to do, flowchart the whole thing.
I'm reading through this and your other threads over at Microchip, and your ideas are half-structured at best. You seem to be hoping that somebody will just come up with the magic code for you and it'll all be done.
Joe's code, a couple of posts above, is a good base for you to add onto. I think the end result that you desire is just as easy as what Joe has written up. Why not just try a few things here and there? Then, when things don't work as expected, post the code YOU wrote and the rest of us can help YOU figure out what YOU did wrong, rather than the other way around. As has been said here before, this isn't a 'drive-thru get your code' forum, although a few would be more than happy to write the code for you, I don't know of any.
After that, you might want to hit the books a little bit and do some reading on the SLEEP command for putting your PIC into SLEEP mode.
