thank you very much joe I see what your saying WIth the triggers But for now that code up there was orginally for no triggers just external buttons that send the rapid low pulses. the loop one is rapidfire auto and loop 2 is burst. What i want to know if i attach a switch to ground than gpio.3 and when the switch is hit once it will go into loop1 or mode 1 which is auto rapidfire and if the swithch is hit one more time it goes in loop2 or mode 2 for the burst so its basically a 2 mode rapidfire and agin the 2 mode is external after i get it working it will move on to the orignal triggers. thanks joe
EDIT: On the code you wrote can I add a option to turn on and of the rapid fire I mean I know I can jsut do this for example
if buttoncheak = 1 than
sleep 6
goto main something like thta but where would i add it.
