New project help rapidfire on 12f683
Results 1 to 28 of 28
Threaded View
  1. #26
    Dec 2008
    Hey after playing around and some testing with my new multimeter I found out this, The top pin is always low or ground the middle pin is 1.41 volt When the trigger is not held down, But when you start pressing the trigger it slowly starts decreasing, the more you hold it down the less the voltage gets. When i held the trigger down all the way It was at 0.31-0.30 volts thats afcourse when its down all the the way but even if you press it a little bit the voltage will decrease a little bit and the bottem pin of the 3 is at 1.61 volt all the time and doesent decrease nor increase. This is afcourse on this version of the controller while the other fires off high but not low like this
    Last Post: - 8th March 2010, 21:58
  2. 12f683 help!!!! L@@K!!!
    By thm ov3rkill in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2008, 23:46
  3. A Temperature & Humidity Data Recorder Project
    Last Post: - 9th July 2008, 19:47
  4. Help on coding/ selecting PIC chip for project
    By lovemeok in forum General
    Last Post: - 27th July 2006, 20:21
  5. A category for Project Ideas
    By Pic_User in forum Forum Requests
    Last Post: - 23rd June 2006, 08:29
