Quote Originally Posted by astouffer View Post
Yeah the $40 price probably keeps most hobbyists away from those displays.
$40 doesn't keep this hobbyist away from anything...just don't have a use for them at the moment...Wait a minute! Since when did I have to have a use for something to buy something!!!
What command would write the screen into ram, writecode?
First thing you have to do is quit thinking about the on chip ram as some sort of special place to put data. Every variable you make is stored in on chip ram, every array, every byte, every x var byte : x = 10 x is ram, ram is x.
If you have an 18F2620 and you:
temp var byte[1023]
You have just allocated 1024 bytes of on chip to be declared as an array by the name of temp to be accessed with a statement such as temp[586] = 56.
