PBP transfer
Results 1 to 3 of 3
Thread: PBP transfer
    Sep 2003
    Vermont
    Unhappy PBP transfer
    Here's an interesting one... My old laptop's screen died. I bought a new mini laptop to replace it for travel. I put my registered PBP2.50a onto the new unit along with my Melabs programmer software and Microcode studios. It all runs fine, until I compile. The old computer compiles and gives me 312 words of working code for the 16F628a.
    The new one compiles and gives me over 800 words of code. The hex code is different also.Needless to say, the new version does not work. The setup is exactly the same for both computers, for compiler , assembler and editor. Exactly! They are both Windows XP units. I tried running both MPASM assembler and PBP. Any ideas? I'm stumped!
    Ron
    What chip is selected in the MCS?
    Sep 2007
    Ron,
    I hate to see that someone else is having the same or similar problem but at least I know I'm not singularly crazy!
    I'm seeing the same thing with my system. The only difference being that it's on the computer that I've been using without issue for the last year and a half. You can look at the thread I started "What have I done now".
    I just posted two hex samples to try to see what's going on. You might want to go under my thread and post samples of working and non working hex files compiled from the same code for comparison. We might be able to figure out if it's a common root cause. And at least you have an old computer that is still able to create working hex files, if I understand you right.
    Hylan
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. Replies: 1
    Last Post: - 23rd December 2006, 10:38
  4. Assembly Language + PBP
    Last Post: - 10th January 2006, 13:54
  5. Newby- PBP wont compile for 18F (MPLAB)
