Driving the SmartDisplay, first impressions
Results 1 to 10 of 10
    The shiftout in the NKKsendByte: routine is always sending a 1, not the data.
    I know I said to send 1 byte, but I didn't actually mean to send a 1.
    Nov 2008
    @	__CONFIG _XT_OSC & _WDT_OFF & _LVP_OFF & _CP_OFF  &_BODEN_OFF
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %10000010 ' Set PORTA analog and right justify
    CMCON = %00000111	'comparators off
    TRISC.3 = 0		'clock
    TRISC.4	= 0		'chip select active low
    TRISC.5 = 0		'data
    RPM   VAR WORD
    IPS   VAR WORD
    clock	VAR	PORTC.3
    sdata	VAR	PORTC.5
    INCLUDE "NKK.pbp"
    Include "modedefs.bas"
    shiftout clock,sdata,MSBFIRST,[$40]	'led color command
    shiftout clock,sdata,MSBFIRST,[%00111011]	'teal
    shiftout clock,sdata,MSBFIRST,[$41]	'led bright command
    shiftout clock,sdata,MSBFIRST,[%11111111]	'full bright
    Initialize:
        NKKmode = 6                   ; 4x5 mode
    @   NKKclear                      ; clear the NKK screen buffer
    @   NKKtext (1,1,"RPM:")          ; row 1, column 1
    @   NKKtext (3,1,"IPS:")          ; row 3, column 1
    @   NKKtext (4,2,"0.")            ; row 4, column 2
    ;----[ The Main Loop ]------------------------------------------------------
    @   NKKword (2,2,4,right,RPM)     ; Display RPM
    @   NKKword (4,4,2,zeros,IPS)     ; Display IPS
    @   NKKupdate                     ; Send data to the display
        RPM = RPM + 10
        IPS = IPS + 2
        PAUSE 1000
    GOTO Main
    ;----[ Send Command to start Display Data Transfer ]------------------------
    NKKstartData:
    	shiftout clock,sdata,MSBFIRST,[$55]	'xfer data command
      ; *** this subroutine should send the $55 command ***
    ;----[ Send 1 byte to the NKK display ]-------------------------------------
    NKKsendByte:
      ; *** this subroutine should send one byte at a time ***
      ; *** The byte to send is in the variable OutByte    ***
      ; *** Send the data MSB first                        ***
    Hope everyone enjoyed their time off this past week. Now back to coding
    Compiling the test program as above lights up the back light but nothing gets displayed. I tried defining the IPS and RPM vars with values in case that was the problem but nothing changed. Any ideas?
    Guess my hint didn't work too well.
    Put this line in the NKKsendByte: subroutine.
    	shiftout clock,sdata,MSBFIRST, [OutByte]
    Nov 2008
    Doh, it was pretty much spelled out for me. Everything works but I had to change the NKKsendByte: to LSBFIRST because it was garbled. Again many thanks and let me know where to send the case of beer
    Thumbs up
    Great! I'm glad you got it working.
    I'd REALLY like to have that BEER. But it always seems to go FLAT after shipment through Email.
    If you have a camera, I'd love to see a picture of the display working.
    Maybe next to your thumb, or a coin or something.
    Best regards,
  1. Driving a SmartDisplay? (NKK)
    By astouffer in forum mel PIC BASIC Pro
    Last Post: - 1st December 2008, 16:26
  2. Problem driving a laser pointer
    By Louis Cimon in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2008, 14:49
  3. Replies: 1
    Last Post: - 1st May 2008, 05:07
  4. driving APR6008
    By mech in forum mel PIC BASIC Pro
    Last Post: - 6th December 2006, 18:37
  5. Driving a logic-level HEXFET
    By thelightbrain in forum mel PIC BASIC Pro
    Last Post: - 10th November 2004, 23:34
