PORTA Logic - Be the processor
Results 1 to 30 of 30
    I can see a lot of really nifty tutorials with your Flash gadgets. Very cool stuff.
    This reminds me of the Microchip eLearning Flash-based training modules. Nice work
    DT. P.S. I had a 145 just before this one, but thought I could beat it. Didn't happen...;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sounds interesting. I'd like to see those.
    Can't seem to find them though. Google let me down?
    Uh huh, suuure you did ...
    My next one will impose a 10pt handicap for anyone with Bruce in their username.
    not
    Here's the link to Microchips flash training modules; http://techtrain.microchip.com/x14/
    -Bruce
    tech at rentron.com
    Thumbs up Thanks Bruce!
    Those are pretty interesting.
    Gives me a few ideas too.
    Default I/O Woes on 18F4420
    Your game was fun, I got a 109 (better hit the books again)
    I have been migrating an application from a 16F887 to a 18F4420. After some debug (few hardware issues - oops!) the two output ports are doing great (B & D). Thanks to you Darrel my Timer 01 interupt is clicking away. I was able to change the config1h register to use the 4x PLL oscillator. But I am having trouble getting my input ports (A & E ) to function (very ashamed )
    Oddly enough, there is one bit of the A port that works (bit 4). The rest of inputs on port A and E ignore me. Hardware check of pins show normal (pulled to Vdd via resistor with contact closure dragging them to Vss when applied)
    Below is the I/O setup from my program:
    ' ~~~~~~~~~~~~~~~~~~~ Define A I/O Port and Define Analog I/O ~~~~~~~~~~~~~~~~~~~
    PORTA = %00000000 ' clearing bits as recommended in data sheet
    ADCON0 = %00000000 ' turn off all A/D
    ADCON1 = %00000111 ' turn off all A/D I/O points - make digital
    TRISA = %00111111 ' bits 0-5 declared as inputs
    ' ~~~~~~~~~~~~~~~~~~~ Define B I/O Port ~~~~~~~~~~~~~~~~~~~
    TRISB = %00000000 ' bits 0 declared as output
    ' ~~~~~~~~~~~~~~~~~~~ Define C I/O Port ~~~~~~~~~~~~~~~~~~~
    PORTC = %00000000 ' clearing bits as recommended in data sheet
    TRISC = %11110000 ' bits 4,5,6,7 defined as inputs
    ; LATC = %00000000 ' bits 0,1,2,3 declared as output
    ' ~~~~~~~~~~~~~~~~~~~ Define D I/O Port ~~~~~~~~~~~~~~~~~~~
    TRISD = %00000000 ' bits 0-7 declared as output
    ; LATD = %00000000
    ' ~~~~~~~~~~~~~~~~~~~ Define E I/O Port ~~~~~~~~~~~~~~~~~~~
    PORTE = %00000000 ' clearing bits as recommended in data sheet
    TRISE = %00000111 ' bits 0,1,2 declared as inputs
    ' bits 3-7 declared as output
    ' to prototype Application inputs
    Does this look as you would expect? Got any other areas you would recommend I check - I think I am close to being able to recite the 18FXX2 data sheet, but it doesn't mean I might be overlooking something.
    Try ADCON1 = %00001111. Deduct 1 point from your score...;o}
    -Bruce
    tech at rentron.com
    Default Many thanks
    Wow Bruce you are correct! But did I miss an errata sheet or is my trouble reading the table in the attached document
    In any event I am back in the running. I owe you for this. You can take five of my points and add to your score.
    Thanks again
  1. Cant change target processor to compile
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 9th November 2009, 19:31
  2. Replies: 0
    Last Post: - 3rd February 2009, 00:23
  3. PIC's ports individual bits manipulation - how to?
    Last Post: - 27th February 2007, 23:34
  4. 16f876 PortA set-up trouble?
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 20:31
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
