Ds1820, ds18s20, ds18s20+
Results 1 to 2 of 2
    Jan 2008
    Default Ds1820, ds18s20, ds18s20+
    What are the differents between the three models?
    Can I use the same PBP program for all these three models?
    The only different I have understand is that DS18S20 has longer conversions time then DS1820 but what is the different on DS18S20+?
    Edit:
    In the datasheet i found what + stands for.
    + Denotes a lead-free package
    Jan 2008
    OK i will answer myself now, maybe this post can be useful for others whit the same question?
    Architecture: The DS18S20 uses a bandgap temperature sensing architecture rather than the dual-oscillator architecture used by the DS1820. This architectural difference is invisible to the user.
    Specification Differences: The primary specification difference between the two parts is the temperature conversion time: DS1820 = 500ms (max) and DS18S20 = 750ms (max).
    Software Compatibility: The DS18S20 is software compatible with the DS1820 in most applications.
    Hardware Compatibility: The DS18S20 is available in TO-92 (DS18S20) and 8-pin SOIC (DS18S20Z) packages. The DS18S20 (TO-92 package) replaces the DS1820 (PR35 package) since both packages are 3-pin packages with the same lead pitch. There is no replacement package for the DS1820S (16-pin SSOP); however, the DS18S20Z (8-pin SOIC) provides a smaller surface mount package option.
  1. DS1820 display with 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 10th April 2008, 13:12
  2. PIC lcd ds1820
    By wchpikus in forum mel PIC BASIC
    Last Post: - 24th May 2007, 14:46
  3. Using DS18S20 vs DS1820 with 4x7 LED Displays
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 16th October 2006, 04:36
  4. DS1820 again
    By paxmowa in forum mel PIC BASIC Pro
    Last Post: - 10th January 2006, 14:49
  5. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 10:36
