ADCIN Problem
Results 1 to 34 of 34
Thread: ADCIN Problem
    Dec 2008
    Ok guys,
    1.) Changed to 8 bits.
    2.) Put caps 1uF on each side of the pic on the Vdd and Vss.
    3.) No microwaves, no TVs, no fluorescent lights close to my project. I scanned my desk for any possible interferences but there is nothing.
    4.) Put a .1 uF parallel with a 100K resistor at the ADCIN pin. Tried with different caps.
    5.) Added a LED and it blinks ok. Do not see any skips or changes on the blinking rate.
    6.) The only thing is that I could not find RF chokes locally (I'm in Panama Central America). I put a ferrite on the cable to the ADCIN pin just in case.
    All of the above and problem still persists. I have not seen a single change on the way the erratic readins of voltage behave. I tried to see if there is a pattern to the erratic readings but can not see one.
    Is this problem with erratic voltage readings something usual or rare? I have continued searching the web and I don'yt see anything that really talks about this.
    Could this be a problem with the PIC18F4620? Or maybe I should not be using a breadboard?
    Javier.
    With what you describe, I feel certain the issue is not of hardware. I have used the ADC on a breadboard, with a far cruder supply (no RF chokes/filters) without a problem.
    I have never used a PIC18F4620, though. Which is why I suspect perhaps its to do with some settings specific to that chip.
    Could you temporarily replicate that with another PIC, say a 16F877?
    Dec 2008
    Unfortunatelly, I only have the 4620. I can not find pics locally. I am already looking to order more different pics from the states.
    How erratic are the readings? Could you post a 'stream' of the readings?
    Just to rule out the basics, if you ground the input, do you get a consistent '0'? and connect it to +5, do you get a consistent '255'?
    Or a consistent 1023...
    I didn't see the " CMCON = 7 " ... Default value ... yes, but, just to be sure of .
    Also, did you try to tie RA.0 to ground or to RA1 ... it makes a superb noise input, as left floating !
    Note unused portA pins should be tied to ground through 10 k resistors ...
    - or use RA.0 as input !!! and other RA pins as outputs, if unused.
    Smile
    ADC set to 8 bits, remember?
    Wink
    Quote Originally Posted by JavPar View Post
    Ok guys,
    Javier.
    Hi, Javier
    Nothing about config.
    BUT Your supply filtering looks to me a bit weak ... ( USB voltage stability ... ahem !!! )
    I have a board with '452 and another with '2520 ... 220µF at the card pow. input + 10 µF Tantalum + 0.1µF ( closest as possible from PIC pins ).
    see scheme attached.
    Some capacitor tank ( > 10µF Tant.) close to your LCD could be useful too ...
    Dec 2008
    Hey guys I really appreciate your help. Alain, that schematic that you posted has made me think. I used my multimeter to test input voltage right at AN0 pin and the voltage is steady at 2.432 with the last gidit sometimes changing to 1.
    I also noticed that measuring voltage in the output pin to my LCD I get oscillating 123mV to 127mV. That makes me think that possibly my PIC is doing something during the A/D convertion that it is outputting oscillating readings? The oscillating readings go out not only to my LCD pin but also to my PC pin.
    Had a similar problem my self - turned out to be the inverter for my LCDs backlight. My voltmeter gave no indication of any fluctuations.
    Dec 2008
    Alektric, I removed the LCD from the project and still the problem persists.
  1. ADC or ADCIN "bias" problem?
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 26th February 2010, 19:39
  2. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  3. electrical problem adcin
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 28th March 2007, 22:52
  4. adcin problem
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 17:47
  5. weird 12F629/675 problem
    Last Post: - 7th October 2004, 01:08
