I have made a separate project just to clean it. I am reading voltage from the project or voltage from a ac/dc wall power supply sending 3V. Also I have tried reading a angular rate sensor and last tried reading nothing and still get erratic readings.
I use a digital multimeter to read the voltages and the readings are 100% stable on the meter.
For supply I have been using the 5 volts from my PC's USB port. I also tried using a wall-plug type supply suppliying 5V.
I cleaned my project so now I only have an LCD, a 4.7K resistor at pin 1 MCLR/VPP, on/off switch, reset button, 8 Mhz crystal with two 15pF from the crystal to ground.
Even with the new clean project, I still get erratic readings.
This is crazy. Will continue trying tomorrow. Thanks for your help.
