Laser data transmit: how to
Results 1 to 5 of 5
    xnihilo's Avatar
    xnihilo Guest
    I have a laser fence that uses a photo diode/photo transistor. The only problem is shielding from ambient light. But I am not modulating either, just a make / break setup. Modulating should help.
    Hello,
    Yes, this is a good start.
    I may use a LDR. The receptor should be optimized for the wavelength of the laser. I could not find any relevant info on the web, quite surprising...
    It should be fairly simple to replace an IR led / IR receiver by the laser equivalent...
    I used the laser diode from a laser pointer. The wave length on the label was 660-680nm.
    Nov 2006
    Murrieta, CA
    Default Sigh ....
    Ok... STOP !
    Before you burn your retina... please note that all lasers emit harmful IR radiation and should not be used in this application.
    sounds to me that you are not using the correct Lens for the IR LED and Receiver.
    Please read this thread http://www.lasertagparts.com/mtoptics.htm
    for you to actually transmit data with a real laser you would need an infrared laser which is Extremely dangerous because of the concentrated amount of invisible IR radiation.
    Please read this topic on Why IR is bad
    There are 10 kinds of people. Those that know binary and those that do not.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 02:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
