Confused on an IF...THEN decimal # check
Results 1 to 17 of 17
    Dec 2005
    Salt Lake City, Ut, USA
    Question Confused on an IF...THEN decimal # check
    Hello all,
    I've got my serial comms working great, thanks to all of you! As I'm running my code through the sim, I'm trying to validate the incoming decimal address, with no success. It goes something like this:
    hserin [wait("A"),DEC3 boardadd]
                hserout ["Board received A",DEC3 boardadd,13,10]
                IF (boardadd = 000) OR (boardadd > 254) THEN     'THIS IS NOT WORKING!!!!!
                    hserout ["Error: Address ",DEC3 boardadd," not valid! Please use 001 to 254.",13,10]
                    write 0,boardadd
                    high Progled
                        pauseus 50
                    low progled
                    read 0,boardaddep
                    hserout ["Board address set to ",DEC boardaddep,13,10]
    The "=000" works, but the ">254" doesn't. The code allows me to enter >254. Am I missing something here, or am I trying to compare 2 different formats? I've tried the following with no success:
    IF (DEC3 boardadd = 000) or (DEC3 boardadd > 254) THEN...
    Hope one of you can help. Thanks a million!
    C
    What size of variable is
    boardadd
    If it is not a WORD size that could be the problem.
    Dec 2005
    It's a byte. That's not ok for 1-256? If that's the case, through your eyes, will I need to change anything else in the code, besides the VAR? Thanks a bunch!
    C
    Dec 2005
    Sorry, mis-spoke...
    BIT 1 0 to 1
    BYTE 8 0 to 255
    WORD 16 0 to 65535
    LONG* 32 -2147483648 to 2147483647
    My bad...0 to 255
    Thanks again!
    C
    A byte is 256 steps starting at 0.
    Not knowing the value of "boardadd" I will make a guess and say changing it to WORD is all you have to do. Pulling the three digits of boardadd, 999 would be the largest number... right?
    Dec 2005
    thanks mackrackit. the BoardAdd is stored in EEPROM 0, with a min value of 001 to a max value of 254. I hope that answers what your trying to ask me?
    C
    Quote Originally Posted by kevlar129bp View Post
    That is what little or no sleep does for me, makes me babbble more than usual.
    If 254 is the max then how could this ever happen?
    As Duncan says "I will get my hat now".
    Hello all,
                    write 0,boardadd
                    high Progled
                        pauseus 50
                    low progled
                    read 0,boardaddep
    C
    I have a thought . . . Right, wrong or otherwise . . .
    your code . .
    have you tried . . . ?
    IF (boardadd <1) OR (boardadd > 254) THEN
    Dec 2005
    Thanks for your input Joe. If I remember correctly, I tried so many different ways, but to no avail. Although, Dave's solution worked flawlessly so far! Hey guys, without me starting a new thread, I've got 1 more question. This "Master Board" PIC is actually going to be sending serial out to "Daughter" boards with their own PICs. A quick snippet of my code goes like so:
    case 2
    serout portB.1,n9600,[UpdPinLvl] 'CAT5 JACK 1, PIN 2
    GOTO Start
    Is this (basically) the correct syntax if the signal does not route through a MAX232? BTW: UpdPinLvl is a 8 bit integer. OK, so 2 questions: Correctness of syntax aside, what is roughly the max distance between Master and Daughter I could expect with driving it TTL?
    Any thoughts would be great!
    C
    No it's not. A byte is OK for 0-255.
    A byte has 256 states... ZERO is one of them.
    case 2
    GOTO Start
    It the variable is a number you may want to consider this from the manual
    A numeric value preceded by a pound sign ( # ) will send the
    ASCII representation of its decimal value. For example, if W0 =
    123, then #W0 (or #123) will send “1", “2", ”3".
    Distance... Depending on the cable, connections, and the amount of noise in the environment, 30 to 50 feet is about the max distance you can expect. Could get a little more, maybe less.
    Dec 2005
    Thumbs up
    Thanks guys,
    I think I'll just mess with the daughter board when I have more time...the master board was my main focus, and it's good so far. As for the cabling, I'm an Audio-Video-Security installer, so cat5 is a natural fit for me. This is what I've got so far...so we'll just have to road-test the max limits.
    [IMG]<table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/nK_RiB5vTk6ukG3L5lkzJg"><img src="http://lh6.ggpht.com/_B18XeDRTquI/SUPWW2AHgDI/AAAAAAAAACA/xrDpzvtT7Ik/s144/MOTHERBOARD.jpg" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/kevlar129bp/SerialControl">Serial Control</a></td></tr></table>[/IMG]
  1. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  2. Help for decimal conversion
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 19:20
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  4. 16bit variable and degrees conversion
    Last Post: - 2nd May 2005, 18:27
  5. Convert a word variable to decimal
    Last Post: - 4th December 2004, 21:02
